Slk 170 drag link - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Marct
  • 1 Post By Marct
  • 1 Post By Aycee
#1 Old 01-19-2013
Vehicle: 2005 AMG SLK 55 - currently for sale
Other Toys: 2011 Mustang, Ford F-150 lightning, Hilux 2.8 V6, CRV, Aprilia RSV Millie
Quoted: 17 Post(s)
Slk 170 drag link
Due to my steering feeling awful and a tiny bit of play I decided to change the idler bush, damper and drag link. Gsf had good prices so I bought it all and stripped the car.
I have now found that the part of the drag link between the ball joints is different.
On the old one this bent downwards to miss the engine/gearbox but on the new one it goes upwards.
As Gsf list two numbers which on their website look the same (correct to my car) they have checked everyone they have in stock and all bend upwards.
Has anyone seen this before and what should this different one fit. I am now stuck with the car off the road and have had to order one from a main dealer for over 400 but I am worried it will also be wrong.
Thanks in advance
Marc
Hombre1509 likes this.
Marct is offline
#2 Old 01-19-2013
Thumbs up
Thanks in advance
Marc
Check out my thread:
https://www.slkworld.com/slk-r170-gen...alignment.html
Especially this post:
https://www.slkworld.com/slk-r170-gen...tml#post351228
The total cost with the OEM damper, Lemfoerder steering idler, and Lemfoerder drag link came up to $284!!! Got this installed about a week ago and everything's great! Perfect fit of steering drag link from BMA autoparts! My car steers like new! Especially after I have changed two hydraulic steering hoses and flushed the steering fluid! Runs like a champ right now!!!
#3 Old 01-19-2013
Thumbs up
You can also PM me your VIN and I'll look up the correct part number for your car and can tell you couple online stores which don't charge arm and leg and sell Lemfoerder! I'm happily satisfied with them! Just ordered new engine and transmission mounts from here http://www.rmeuropean.com/default.aspx + discount code %5 =)
Will do them some time later!
#4 Old 01-20-2013
Quoted: 17 Post(s)
Thanks for the links. Can you remember if your drag link bent lower between the middle joints or higher. All the pics on eBay show it going down but the supplier has checked the last 18 in the uk and they all bend upwards.
Due to time I ordered from mb but because of the weather it's been delayed 3 days so I have no car and I am worried the wrong one will arrive as the illustrations seem to mean nothing.
Marct is offline
#5 Old 01-20-2013
Smile
Please see this post:
https://www.slkworld.com/slk-r170-gen...tml#post358397
I have uploaded some pictures of my new drag link! I don't know if there was a difference between pre- and post-facelift models... As I've said, PM me your VIN and I'll look up the correct part number for your car! But if you buy it from the dealer usually they ask you for your VIN and thus send you the correct part. Hope you'll get the correct one since you already ordered!
#6 Old 01-20-2013
Quoted: 17 Post(s)
Hi, thanks for the links. Your is the same as the one I bought which is wrong for mine. I need the bend in the middle to Go the other way.
Marct is offline
#7 Old 01-20-2013
Exclamation
Ok, the MB EPC catalog shows that your part number is different from mine: A 170 463 0015 To me it only means that there's a difference in drag link between pre- and post-facelift models.
Yes indeed, they are different! here's an old post I came up with:
https://www.slkworld.com/slk-r170-gen...tml#post244753
"You need to watch things with this because its pre and post facelift. For instance the centre drag link for the steering is different as I found out through painful experience."
Since my post-facelift (2003) part # is different A170 463 0115
#8 Old 01-21-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Is there a difference for left hand drive vs. right hand drive cars?
Len
1999 E300D 215,000 miles
sokoloff is offline
#9 Old 01-21-2013
I would assume there is a difference in drag links since the idler arm needs repositioning to the other side and the "lip" for mounting the steering damper (which is on the drag link itself) also needs repositioning.
I may be wrong but it's my first guess.
#10 Old 01-23-2013
Quoted: 17 Post(s)
Hi, got the one from the main Dealer and its correct. Also only came to 313 with track rod ends but no nuts.
Its on but I can't use it till the weekend when I can have it tracked.
It does look like the early cars need the centre joints pointed upwards with the bar dropping down in the middle.
Ref LHD and RHD question above, would the drag link be the same or does the steering damper mount on the opposite site. Mine is RHD with the early link and the drag link conects to the damper on the drivers side.
I would have thought the idler and steering box connections wouldn't have made a difference.
JaysonM likes this.
Marct is offline
#11 Old 01-23-2013
Quoted: 17 Post(s)
I can get some pics on my phone of mine if it helps but I can resize it for posting
Marct is offline
#12 Old 06-01-2013
Quoted: 37 Post(s)
Hi, apologies for re-opening an old thread. I am in the same situation and need a drag link for my facelift SLK230. Mercedes part no A1704630115, Lemforder 21672 01. The cheapest I can find in the uk is 185 from ECP. Does anyone have any links to alternative suppliers.
Thanks, Mark
Mark999 is offline
#13 Old 06-01-2013
Thanks, Mark
You don't need to apologize =) I only have some online stores for the US. but I checked with them and they charge arm and leg to deliver to the UK! $150 average... Wait till some folks from England jump in!
#14 Old 06-01-2013
Aycee's Avatar
Vehicle: 2002 Blue SLK 320
Using the code MERCCL25 you can get 25% off ECP
JaysonM likes this.
Aycee is offline
The Following User Says Thank You to Aycee For This Useful Post:
SLK tires for sale at this link tsts SLK R171 General Discussion 0 01-04-2012 08:29 PM
SLK 320 Centre Drag Link JustinJoyit SLK R170 General Discussion 1 06-08-2011 04:16 PM
SLK 280 VS others HwoALanG Driving Stories 1 03-31-2011 09:25 AM
Just bought a new 171 SLK 200k.. Use to own a 170 230k. James C100 SLK R171 General Discussion 14 05-02-2010 10:22 PM
