P0560 System Voltage, ABS BAS/ASR - Mercedes Benz SLK Forum
  • 1 Post By Wheels52
#1 Old 01-08-2013
Vehicle: 2000 230K blue
Other Toys: A Prius! Yes... that's right... a f.... Prius!
I have a SLK 230K which was fine, but suddenly it started doing weird things. After driving for a while it turned on the BAS/ASR and ABS lights but it was still fine, the lights went off after powering off the car and restarting it... Then, it was stuck on limp-mode (Stuck transmission on second gear and a weird "airplane like" engine sound). I used a scanner, and it returned a P0560 System Voltage... left the car without using it for a couple of hours and when it cooled down it was normal again... After a few days I noticed that when it revs up fast the lights come back, and if the acceleration is strong enough it goes to limp-mode... When the car is used for a few hours gets even worse!!! Today I checked the battery, when the car is off the battery shows 12.8V, when turned on, it show a steady 14.6... but when I accelerate the car it goes all the way up to 19+ volts!
Oh also... the first symptom was my Parrot Asteroid radio wasn't working... and now when the ASR/BAS ABS lights come up, the radio stops working and the windows won't go up/down....
Sounds like alternator or regulator? Any experience with this? Is it normal that a measuring the voltage on the battery when the car accelerates go up to 20V?
Almost forgot to mention: Today it also gave me a "Large Fuel Leak" Code, and the fuel light started blinking when the tank showed (And I'm positive about that) over 3/4 of a tank. A friend said that when a system voltage malfunction is present, the ECU might get a bit "crazy"....
Thanks!
mchaconcr is offline
#2 Old 01-08-2013
Wheels52's Avatar
Vehicle: 1998 SLK Black Opal
Other Toys: 2010 SV6 Commodore 210kw, 4.7 Mtr Runnabout
Hi
Interesting problem
My son has a 2008 Ducati S1098
His indicators would stop working after the engine reached above normal operating tempreature when waiting at the trafic lights etc. then when cooled they would begin working ok again.
The problem is the voltage regulator has malfunctioned. He can similate this be reving the engine as the revs increase the volts increase up to 20v.
I would have an auto electritian check the voltage regulator to ensure it is regulating the voltage.
some items are voltage protected some are not.
hope this helps.
mchaconcr likes this.
[SIGPIC]Old but not broken!!
Wheels52 is offline
#3 Old 01-08-2013
http://www.amazon.com/gp/product/B007Y883DC/ref=cm_cr_mts_prod_img
This is the alternator... avoid it!!!
#4 Old 01-22-2013
Indeed... it was the alternator! Originally I thought it was the voltage regulator... replaced it... but the voltimeter kept showing 25+ volts peaks... and the computer was nuts reporting all kind of things... replaced the alternator. and everything is fine now.
The Following User Says Thank You to mchaconcr For This Useful Post:
Tags
p0560
Cartronics iTronic BT Bluetooth install -1- SLK R171 Class DIY 18 07-03-2013 07:09 PM
Nav system bug/Comand restarts SheltonJ SLK R171 General Discussion 3 06-26-2012 01:27 PM
ABS and ASR Light - Disabled System nickygee11 SLK R170 General Discussion 12 06-22-2012 09:04 AM
ABS & ESP malfunction not fixed by dealer gd197 SLK R171 General Discussion 23 04-12-2012 01:51 AM
Motorola After Market Hands Free Phone System StormRedAMG General Discussion 2 04-05-2007 07:40 AM
