Turn Signal issue - Mercedes Benz SLK Forum
#1 Old 01-06-2013
Vehicle: 1999 SLK230
Turn Signal issue
My driver side turn signal works, my hazards work, but my passenger side turn signal doesnt work at all. Doesnt light up, nothing
The control box makes the clicking noise, I took it apart and cleaned the contacts on the relays, even left the cover off when i plugged it back in.
The relay works, but when I turn the turnsignal switch to turn right, it just clicks really fast, and no lights light up.
Help? Suggestions?
Saphykitten is offline
#2 Old 01-07-2013
Vehicle: 2005 SLK350 MT
Quoted: 19 Post(s)
Simplest thing is bulb. You don't mention whether front, rear or both? If both relay may be problem.
G.
gdb069 is offline
#3 Old 01-07-2013
Wheels52's Avatar
Vehicle: 1998 SLK Black Opal
Other Toys: 2010 SV6 Commodore 210kw, 4.7 Mtr Runnabout
Check bulb in same side mirror housing
[SIGPIC]Old but not broken!!
Wheels52 is offline
#4 Old 01-07-2013
SLK model is a 99, doesnt have mirror turn signals.
All bulbs work, since side markers and both front and back turn on when I have the hazard flashers on.
side that isnt working is the passenger side on a left hand drive model (US)
Took the relay housing apart, the relay clicks, doesnt stick, it just clicks really fast, and doesnt seem to provide any power to the passenger side turn signals (both front and back and side marker) when the switch is turned. Its really boggling, since the driver side works just fine, and the hazard flashers work just fine, and I assumed they were on the same relay board.
Also there is only one 15a fuse that controls that whole circut, in the panel by the steering wheel, and it is fine.
The only thing I can think of is that its an additional circut that has fried, that provides the switching power to only the passenger side? But I have no idea how that board is laid out or if anyone else has ever had this problem. I cleaned the contacts on the relay like previous forums suggest when the turnsignals turn on, but dont click, but that doesnt seem to be the problem I am having, and I havent read any forums where this has happened to someone else.
Any insight would be helpful, I would like to explore my options before replacing the 700$ board, just to find out, its not the relay board.
#5 Old 01-09-2013
Any help with this? ideas? Throw me a bone here
#6 Old 01-09-2013
Quoted: 902 Post(s)
Switch all bulbs left-to-right and see what happens?
efair is online now
#7 Old 01-11-2013
Fairly sure the bulbs are good, because the hazards flash both the front, rear, and side markers.
No one else has had this problem? I cant find anything similar to this in the forum.
#8 Old 01-11-2013
If the relay is clicking faster than normal I would suspect that is the problem
JonB is offline
#9 Old 01-12-2013
But the same relay is used for the driver side turn signal and the flashers, and they work just fine? Is there a separate circuit that sends power to the relay for each side that I should look for?
#10 Old 01-12-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Possibly high resistance in the indicator switch on the steering column. Contacts for left turn are fine, contacts for right turn dirty. Must be worth a look.
Woolly is offline
#11 Old 01-12-2013
Do a search for the multi function switch, i had to replacemine a few years ago with the same problem you have.
#12 Old 01-13-2013
LIL DON SLK's Avatar
Vehicle: 2009 SLK 55 AMG White 8 cylinder
Quoted: 143 Post(s)
There was a recall on the total rear bulb assembly on my SLK 2001 320. MB replaced both of mine plus refunded me for the ones I had replaced.
I found this oN THE RECALL
https://www.slkworld.com/slk-r170-gen...ey-recall.html
LIL DON SLK is offline
#13 Old 05-06-2015
All of my lamps work except my right (pass) side liscense plate and like you, when i turn my drivers side blinker on the front and the mirror blink but the rear bulb does not light or blink and i checked that they work off the battery and the bulb and socket are new.
INFIELDDANIEL is offline
3357A Turn Signal Bulbs Versus PY21W? mb911 General Modifications R171 2 11-15-2012 12:38 PM
Turn signal in mirror, right - Malfunction gdb069 SLK R171 General Discussion 8 03-05-2012 01:21 PM
Turn signal issue or not? jfpslk SLK R171 General Discussion 2 12-11-2010 01:36 PM
