gas door locking mechanism - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Woolly
  • 1 Post By jbanks15
  • 1 Post By Woolly
  • 1 Post By JonB
#1 Old 12-28-2012
Vehicle: 2001 slk320
Other Toys: john deere tractor
I noticed that my gas door lock is missing , does anyone know how to get to it ?
I have a constant popping sound in the trunk and i'm wondering if that could be the cause. post pics if you have them .. thank you !
i already did a search on gas door lock, but found nothing .. thanks in advance as usual , this site rocks !! tons of good info!
rdinky1 is offline
#2 Old 12-28-2012
The gas map door lock works of the PSE pump. The little plunger mechanism is probably a dealer item.
#3 Old 12-31-2012
any idea how to get to it? without taking the entire car apart ?
I can hear popping ..i'm thinking that could be where the noise is coming from.
rdinky1 is offline
#4 Old 12-31-2012
I think you're referring to this diagram:
Part no. 80 (A2108001175) "Filler Neck Flap". I would assume that you can access it from the trunk but you might want to remove the side panel in the trunk. To do this I think the central back panel also needs to be removed . So you might want to spend some time over there.
#5 Old 12-31-2012
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If you take the liner out of the rhs of the trunk, you'll see a unit that looks like a small hedgehog/porcupine - with a load of plastic pipes coming out of it. That is your PSE vacuum pump. You might be able to trace one of the tubes up to the gas flap lock, and if you are very lucky, the lock might still be on the end of it, just pushed out.
JaysonM likes this.
Woolly is offline
#6 Old 12-31-2012
Quoted: 6496 Post(s)
Jason is our new epc-net person! Yay!!!!
JaysonM likes this.
#7 Old 12-31-2012
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
I'll stick to hedgehogs!!
JonB likes this.
Woolly is offline
#8 Old 12-31-2012
Glad I could help, Jeff!
Wolly, decipher please . Oops, never mind got it
#9 Old 12-31-2012
Here are some treads:
How to get to the PSE pump! Very good thread!
http://www.benzworld.org/forums/r170...fit-check.html
Also,
Check to see if PSE if functioning correctly:
http://www.benzworld.org/forums/r170...ons-guide.html
And how to fix it. But this is for the other model. However, the concepts I think is similar.
http://www.benzworld.org/forums/w140...urrection.html
#10 Old 12-31-2012
i found the pump and actually dried it the other day , it was acting up after the snow storm came through... can't trace the tube from there.. it goes into neverland on a wiring harness.... i'm just hoping there is an easy way to access it without a complete tear down...
rdinky1 is offline
#11 Old 01-20-2013
Silbery's Avatar
Vehicle: 2004 SLK 320
I seem to be in need of a number 25 part from that diagram, as the little nipple part of my drivers side door is broken off into the vacuum hose. Can anyone tell me the name and part number of that little gray piece that the vacuum hose hooks onto?
Silbery is offline
#12 Old 01-20-2013
part 25 is called 'coupling' and the part number is A2028000453
taken from a 230 vin since i do not have your vinnumber
JaysonM likes this.
#13 Old 01-20-2013
Whats the difference between a Range Rover and a Hedgehog ??
Woolly likes this.
JonB is offline
#14 Old 01-20-2013
I see Woolly Knows the answer
JonB is offline
#15 Old 01-20-2013
Thumbs up
Jeff is right! I ordered two of those when I was fixing my vacuum flap actuator.
#16 Old 01-21-2013
Silbery's Avatar
Thanks for the help...I'll get one tomorrow if the Benz dealer in St. Louis has them in stock.
Silbery is offline
#17 Old 01-21-2013
Joakim Muth's Avatar
Vehicle: -97 SLK230 OMG Divine Edition
Other Toys: 28' wooden Sailboat
Had the same problem on my 97 SLK230, if you look up in the right corner of the trunk there should be a small plastic cover, pull it open and use a flash light, you will see a RED PLASTIC handle, push it forward (have the gas door open) then you will see a small plunger, that is the locking rod, spray it with WD-40 or some other lubricant, then using the little red handle movit it back and forth a few times, that should solve the problem.
Joakim Muth is offline
Gas tank overfilled thanks to a bad pump nozzle... mrchris SLK R170 General Discussion 5 01-22-2019 01:09 AM
Gas Smell in the Cab. Aggie 08 SLK R171 General Discussion 5 03-14-2012 03:44 PM
Overfilled My Gas Tank...Engine Started Cutting Out peabody SLK R170 General Discussion 14 05-16-2011 10:59 PM
Does the car have to be on for the Gas Guage to work? DashingDaryl SLK R170 General Discussion 2 09-13-2008 03:57 AM
Gas Consumption SLK230 top up/down results SLKCop SLK R170 General Discussion 9 07-29-2008 12:09 PM
