Air Con/Heater and brake squeel - Mercedes Benz SLK Forum
#1 Old 12-24-2012
Vehicle: 1998 SLK230
Other Toys: Highly Modded R6
Hey guys so I just bought an 1998 SLK230 and got it services and the aircon re-gassed.
The car seems to push out hot air even when the air con is on when under hard acceleration and then takes some time to come back to cold air. Any ideas what could be causing this?
Also i had both my front and rear pads replaced as the mechanic told me the pads were cheap nasty ones that had metal in them that caused the brakes to squeel...it is still squeeling after 250km with the new pads in them..any ideas?
underestimateme is offline
#2 Old 12-24-2012
Welcome from New Hampshire, the air con problem may be the Duo valve going bad.
#3 Old 12-24-2012
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Brakes if there is enought meat on the rotors have them cross cut.
Gbarringer100 is offline
#4 Old 12-24-2012
Quoted: 6496 Post(s)
Underestimateme,
Moderator/Founding Member
#5 Old 12-25-2012
Easy fix or new valve?
#6 Old 12-25-2012
New valve would be best.
#7 Old 12-25-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
But I wouldn't just start throwing parts at it. That can get VERY expensive very fast. The duovalve can be taken apart and cleaned up. That may tell you if that's the problem or not. A search will give you the particulars. When you say "re-gassed," the question is why? There obviously was leak. Was it repaired correctly? Is this mechanic a Mercedes specialist? That's often where owners get themselves into trouble.
Len
1999 E300D 215,000 miles
sokoloff is offline
#8 Old 12-26-2012
The car was re-gassed cause the car is 14 years old so figured it would be best to start off with something simple. That has made the aircon a lot colder! My mechanic is a merc specialist who also does ferrari's, porsche and a few other exotics.
#9 Old 12-26-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Okay, good, sounds like you've got a mechanic who isn't going to be learning on your money. If "re-gassing" made the car a lot colder, then that means that the refrigerant was low. That means there must have been a leak. Was that addressed/fixed?
Len
sokoloff is offline
#10 Old 12-28-2012
extremely minor leak over time...all good now
#11 Old 12-28-2012
the drivers (right hand side) air vent sometimes will also pump out hot air whilst the middle and left vents are cold (when set to the coldest setting). Any ideas what it could be?
#12 Old 12-29-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
That's typically either a system low on refrigerant or an issue with the duovalve. Did it just start after your "regassing" or was it an issue before that?
Len
sokoloff is offline
#13 Old 12-30-2012
it was an issue before that. how do i check the duovalve?
#14 Old 12-31-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
I'm not sure if there is a check for it. You can take it apart and clean and lubricate it. You can see if there is any corrosion on it that might be holding it up. I'm sure there's a lot of good posts about it via a search.
Len
sokoloff is offline
SLK 200 UK Rear Brake Strip and Rebuild johnnyg SLK R171 Class DIY 3 04-17-2017 03:37 AM
Spring Cleaning: Get your HVAC ready for with 1Z einszett Klima Cleaner DetailersDomain Caring for your SLK 0 04-09-2010 02:25 AM
6 Car Repairs You Can't Afford to Skip Eduardo General Discussion 7 07-07-2009 02:43 PM
