Additional information SLK320 R170 headlight removal – 2001 - Mercedes Benz SLK Forum
#1 Old 12-20-2012
Vehicle: SLK320 2001
Other Toys: Volvo 242GT turbo, Macan
SLK320 R170 headlight removal – 2001- Additional information
Subject: the 3rd screw doesn’t secure the light, a plastic bolt does, you need to undo both see pics.
Previous posts refer to the simple step of removing 2 screws with the 3rd one found when the blinker lens is removed. However, scant reference is made to how the headlight is 'really secured', and how to undo it. – To get the light out, (the 3rd) large black plastic bolt needs to be partially undone - details in next para (M16 thread, accessed from the underside) and this is partly visible when the 3rd screw is removed.
As you will see the 3rd screw actually fits through the centre of this plastic bolt.
The real function of the 3rd screw is to fasten up the lower front bumper / spoiler, and it seems the designers decided there was no-where else to put the screw, but thru a headlight bolt mount.
Loosening the M16 bolt
To gain access to the underside of the large plastic bolt, you need to undo a few fasteners seen in the wheel arch. The spoiler will then drop down from the guard enough so you can just see the plastic bolt underside. The plastic bolt head hexagon is 24mm across the flats, so slip a large 24mm wide open end spanner onto the nut flats (no imperial size equivalent) and turn clockwise to undo a turn or two just to loosen it a bit only.
The plastic bolt attaches is slipped into a steel tab, the tab being part of the side fender / guard. The tab has a wide slot in it, (and plastic bolt slips into the large dia groove slot in the tab) and when the plastic bolt is undone a turn or two, the headlight can be slid sideways a little to clear the slot and presto you can finally lift it up and the headlight is finally out.
Anthony
Anthony in Australia is offline
The Following User Says Thank You to Anthony in Australia For This Useful Post:
#2 Old 12-21-2012
Originally Posted by Anthony in Australia View Post
Subject: the 3rd screw doesn’t secure the light, a plastic bolt does . . .
Not sure I'm totally clear on that . . . but it was a question I had been scatching my head on. Perhaps when I finally get to working on a headlight in my car!!! . . . it might make more sense to me. (Unless you have some pictures???
lilred320SLK is offline
#3 Old 12-28-2012
Vehicle: 2001 slk320
Other Toys: john deere tractor
i've only removed the driver side, but for me, the corner light had to be removed first, then the main light was held by a plastic tab that had to be moved to the side... i didn't have to go to the fender well at all... so i'm not sure what you are referring to... can you post pics ?
my passenger side headlight has moisture in it sometimes , so I need to take it off to look at it.. i'll see how it comes apart and let you know if I figure it out..
i'm also trying to figure out how to adjust the self leveling lights...
rdinky1 is offline
#4 Old 12-29-2012
leapyfish's Avatar
There is an how to adjust the headlights on page 231 in the 2004 owners manual.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#5 Old 05-02-2013
gr71cj5's Avatar
thank you for the mystery bolt info!
gr71cj5 is offline
#6 Old 05-03-2015
2001 SLK 230 headlight lens only
I need replacement headlight lens only for my 2001 SLK 230. IO don't want the entire housing as my lens are cloudy and these aftermarket cleaners do not get them clear. Any suggestions for am aftermarket source would be greatly appreciated.
rozo10 is offline
#7 Old 05-03-2015
Quoted: 6496 Post(s)
rozo10.
this thread is 2 years old fyi
https://www.slkworld.com/new-members-...d-how-fix.html
Please update your location and vehicle (year?: 1996-2015, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
#8 Old 05-04-2015
cockneyrick's Avatar
Vehicle: SLK 230 03MY
Quoted: 34 Post(s)
Just a tip, but using toothpaste on cloudy lenses can bring em back to new.
Worked on me teeth
cockneyrick is offline
#9 Old 05-05-2015
leapyfish's Avatar
You can search on eBay, or 2001 Mercedes-Benz SLK230 Parts
part #6 & you may need part #7 as well.
not to cheap, but they are brand new!
Vario roof
R170 & R171
SLK 230 320 32AMG
Tags
moisture in headlamp, r170 headlight removal
R170 Projector Headlight Xenon Pattern Pic 9021Jae General Modifications R170 5 05-02-2013 02:26 PM
help me to find the right wheels slk320 r170 powerteam69 General Discussion 23 08-30-2012 09:55 AM
2001 SLK320 Audio friken SLK R170 General Discussion 1 05-15-2011 06:03 PM
Lots of Codes- 2001 SLK320 scholaejuris SLK R170 General Discussion 8 08-31-2010 05:06 PM
