Doors dropping - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By Der Flieger
  • 1 Post By Tolak
#1 Old 12-10-2012
Naffdave's Avatar
Vehicle: 2005 SLK 280 7 Speed Tiptronic In Silver
Other Toys: NSM Sattilite Jukebox
Quoted: 23 Post(s)
Send a message via Yahoo to Naffdave
Doors dropping
Has anyone had experience on early models off doors dropping and not closing properly without a hefty bang. Can they be adjusted easily ?
Dave
Naffdave is offline
#2 Old 12-10-2012
Quoted: 6498 Post(s)
moving to r170 general discussion
#3 Old 12-10-2012
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Your hinges at the front of the door allow for up/down and forward bakwards movement ! I would suggest you loosen them just enough to move the door and not to much so as for the door to be too loose as they are a bit diificult to control . The best idea is to get someone to help you . When I adjusted mine I marked mine up so that I would know the initial position and how far I moved the door ..
curro101 is offline
The Following 2 Users Say Thank You to curro101 For This Useful Post:
#4 Old 12-10-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Do you have a hydraulic lift? With some bits of scrap wood you can support the door with the lift, making sure the handle/pump is on the down stroke (ie handle is angled up), then as Curro suggests, mark the door in its current position, loosen ever so slightly, apply some pressure, retighten test.. repeat as required.
First a question though. Does the door feel tight on its hinges? ie can you lift the door when it's open? If so the hinges are worn and need to be replaced.
GeeJay and curro101 like this.
FUN 4 2
Der Flieger is offline
The Following 2 Users Say Thank You to Der Flieger For This Useful Post:
#5 Old 06-17-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
New thread
Linking old thread to new thread.
Profligate re-threading here!
Tolak is offline
#6 Old 07-26-2013
Vehicle: 2002 SLK230 (130k Miles)
Other Toys: 1991 BMW 850i
Dave
Does it do the same thing with the top up and down? With the top down, these cars have more flexibility that when up. That being said, I would check the sills and door posts for possible corrosion. When a car starts to have the doors dropping it can be a sign that it is starting to lose the structural rigidity because of the dreaded tin-worm.
Dan M.
DTDuck is offline
#7 Old 07-31-2013
Naffdave's Avatar
Quoted: 23 Post(s)
The doors do seem to close easier with the top down. I also notice that sometimes on the passenger door even when it closes properly the glass does not sit into the rubber and have to pop it in by hand.
Dave
Naffdave is offline
#8 Old 08-05-2013
Tolak's Avatar
Dave
Then you may need to check the alignment of the glass in the door.
It can be easily adjusted by use of a T30 driver into the hole on the bottom of the door (behind the plastic bung at the rear corner). Slacken the screw, and move in (towards centre of car) to slacken the contact for the glass. test and repeat as needed. Re-tighten, and refit bung; job done!
Naffdave likes this.
Tolak is offline
LSD doors vs Vertical Doors - which is better? Hakaze General Modifications R171 39 08-27-2016 12:34 PM
Considering Vertical Doors B55 SLK R171 General Discussion 41 10-22-2012 04:36 PM
Force needed to close doors... Raindog SLK R170 General Discussion 4 04-25-2012 01:59 AM
LSD Doors (Need your Vote) noregret4life General Modifications R171 25 03-24-2007 12:07 PM
