R170 SLK230 Condensation in boot (trunk) problem - Mercedes Benz SLK Forum
  • 1 Post By Gbarringer100
#1 Old 12-08-2012
Vehicle: SLK 230 (2002)
Other Toys: Boat Monterey 282SC
Does anyone else have this problem?
It is a little above or below zero centigrade in UK now and I have noticed that things in my boot are very damp. The seals seem fine and I have silicon greased them. I did notice lots of condensation on the metal of the boot which seems very thin. I bought the car 2nd hand was there originally some insulation there?
Is there anything I can do to minimize this problem? I even emptied my garage recently so I could put it in there for the winter as I have a couple of other cars, however, it doesn't fit! I think the builder sized the garage for an original sized mini! I bet you guys in USA wouldn't have that problem
seahope is offline
#2 Old 12-08-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
No there isn't supposed to be insulation in the top of the boot lid. Is the car being parked indoors (eg at work, heated garage). Once the car is acclimatized to the current temperature you shouldn't have any more condensation - it's caused by coming from warm/wet to a colder temperature.
Not sure if you can source some desiccant...
http://humantouchofchemistry.com/keeping-things-dry.htm
FUN 4 2
Der Flieger is offline
#3 Old 12-08-2012
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
How about this , I got some carpet and did my own !
http://www.ebay.de/itm/SLK-Kofferrau...1#ht_578wt_922
curro101 is offline
#4 Old 12-09-2012
Quoted: 123 Post(s)
Use search and have a look here.. One of the first DIY threads I ever saw here (circa 2yrs ago) involved padding the trunk with matching "leather". Similar look to the ebay link.
FUN 4 2
#5 Old 12-26-2012
Thanks. I recently did a DIY job on this using some carpet tiles that I cut to size. However, it hasn't stopped my problem
I have applied some more silica grease to the seal and poured water around it to see where it is leaking but can't see anything. The towel I leave in the depression is sodden though after every rain storm so water is getting in somehow!
I have now covered up the car for the winter, but the cover isn't waterproof. I should have bought a proper heavy duty cover but spent too little. My first relatively cheap cover blew off in last year's gales. The next one I bought has a central cord so it hasn't blown away, but I find it at the back on the car after the slightest breeze. The elasticated bits just can't keep it on the car and it isn't waterproof. I have just bought some luggage straps which I have applied around the boot and bonnet to, hopefully, keep it in place.
seahope is offline
#6 Old 12-26-2012
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Sounds like one of the drains is stopped up and came undone. Do a search on drains and you will find a lot of info on them There are several and check will water will run thur them. Also check the routing of the drains that the rubber tubes are in good condition and no leaks and runs to the out side underneath.
Here is a post to get up started.
https://www.slkworld.com/slk-r170-gen...-cleaning.html
processengr likes this.
Gbarringer100 is offline
#7 Old 12-27-2012
Vehicle: 2002 SLK 230 K tip
Other Toys: Skoda fabia TDI
Trunk lid internal !
A question, the inside trunk lid of our red 170 is painted black. Is this standard, sorry for going off subject.
HZ123 is offline
#8 Old 01-04-2013
Vehicle: silver 230 auto r170
Other Toys: garage full of tools
Send a message via Skype™ to guy999guy
seahope
Hi there.
I had the same problem,think it now fixed,dry for a few days.
I discovered a ripped seal, noticed while lubricating the said seal.
I reglued the seal together using silicone glue and finally patched it with cycle repair kit.
And then relubed, if this does not fix it I need a neew seal set.
Remember the seals need to be checked with the roof partialy down for them to be inspected.
Guy.
guy999guy is offline
#9 Old 03-24-2019
Alex MacGillivray's Avatar
Vehicle: 1998 SLK230
Other Toys: 19' Glasply Sedan spot boat
I'm pretty sure it's just condensation. I live in Alaska and have the same problems in the winter times. A lot of water collects in the truck lid and pours out when I open it up. I have a towel in there that catches the water when I open the lid, but I have to do so slowly or the water runs all over.
I tried to use a desiccant bag, but it couldn't keep up. I think the water has damaged my trunk latch since I have a difficult time closing the trunk now.
Alex MacGillivray is offline
#10 Old 03-24-2019
Quoted: 6492 Post(s)
FYI this thread at least 7 years old
Closed Thread
Tags
condensation
r170 trunk r/h panel streetcar SLK R170 General Discussion 9 08-25-2018 11:23 AM
Inside Trunk / Boot paint ? HZ123 SLK R170 General Discussion 2 05-22-2012 02:33 PM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
Sterring Wheel Paddle Shifter (SLK230 - R170) gummozebra Performance MODS for the R170 6 05-21-2009 10:35 PM
