locked out & no door locks! - Mercedes Benz SLK Forum
#1 Old 11-24-2012
Vehicle: slk 2.3 1998
Other Toys: 1972 tr6, 1971 stag, 1972 stag
hello, i wonder if anyone can help. i have a 1998 slk and my central locking has stopped working with the doors locked and roof up. i don't seem to have any locks on the doors just blanks where the locks should be???
i have replaced the fuse in the boot (uk) even though it hadn't popped and the fob has new batteries. I have managed to open the bonnet and can access the car battery if required
how can i get into my car without breaking anything? any help will be gratefully received. many thanks steve.
sb37 is offline
#2 Old 11-24-2012
Quoted: 6492 Post(s)
sb37,
Thank you,
Moderator/Founding Member
#3 Old 11-24-2012
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Blanks, Check again is it not just a cover that is snapped over the lock. Some had a round plastic cover that snaped over the lock to protect it from weather. Some have had problems with the lock freezing up due to none use over time. Some WD40 sprayed into th lock will free it up.
Once you get it unlocked you should synchronize the remote. Done by aiming the remote eye at car and depressing both the lock and unlock buttons at the same time twice and then inserting the key in the switch with in 30 seconds and tuning it to posistion 2. Make sure you only do this after you are able to get inside the car. Good idea to have second person in side to be able to open the doors if they lock up again while doing this.
Gbarringer100 is offline
#4 Old 11-24-2012
DSCF6001.jpgthis is a pic of the handle, same as driver's side?
does this come off?
sb37 is offline
#5 Old 11-24-2012
https://www.slkworld.com/new-members-...to-my-car.html
#6 Old 11-24-2012
Any luck? The central locking system works on a vacuum , there is a small pump that creates that vacuum. The pre facelift models have a known problem the pse , the circuit boards get corroded and cause all kinds of issues. Replacing the fob batteries may not be enough, most times you have to 're program them.
#7 Old 11-24-2012
still no joy, can't for the life of me find a door lock to open. what is the pse?
sb37 is offline
#8 Old 11-24-2012
it is a pump that regulates the locks among other things. do a search top right for pse pump
#9 Old 11-24-2012
Vehicle: slk230 r170 1999
Other Toys: suzuki gsxr1000+NOS nissan and the odd beer
hi my slk230 is same model key is covered by blank on drivers side
outonmybike1 is offline
#10 Old 11-24-2012
how do you get the bloody thing off?
sb37 is offline
#11 Old 11-24-2012
Vehicle: 2006 SLK 280
Other Toys: 98 Cobra Drag 1600hp
I have no experience with this, but if you can determine which line supplies vacuum to the central locking system from the vacuum pump/tank then you may be able to put a hand or power vacuum pump on that line and get the lock to work. Either that, a coat hanger or a slimjim. Is the battery dead?
Sandpaper is offline
#12 Old 11-24-2012
Quoted: 99 Post(s)
Originally Posted by sb37 View Post
Attachment 27468this is a pic of the handle, same as driver's side?
does this come off?
The driver side should come off some way. See if you can move it a little. The parts book shows as if it snaps off. Can not say for sure how it comes off. It must come off to get to the key slot to unlock the doors if the car battery is dead. Hope someone if a 170 would chime in with better info on removal of lock cover.
#13 Old 11-25-2012
hi again any luck yet getting the blank cover off.some have round disk in key hole others have cover over outside.if you are near bye and have no success i will take a look. I live near Oldham
cheers
Neil
The Following User Says Thank You to outonmybike1 For This Useful Post:
#14 Old 11-25-2012
tried to send a private message to niel (out on my bike) but haven't got enough posts to do it yet so hope he reads this!!!
I live in Ramsbottom, the car is in my garage at home so at least i'm not getting soaked trying to get into it.
my number is 07714301431 if you like to get in touch and give me a hand that would be great.
Thanks Steve.
Has anyone used the coathanger technique to open a locked slk, or do the skinny bars down the doorseal to the glass?
Thanks again steve.
sb37 is offline
#15 Old 11-25-2012
murat orhan's Avatar
Quoted: 26 Post(s)
can you get into the trunk?
murat orhan is offline
#16 Old 11-25-2012
yes the trunk (boot uk) opens.
sb37 is offline
#17 Old 11-25-2012
YAHOO DONE IT!!!!
opened passenger door with a piece of copper brake pipe with a hook on the end from drivers side and pulled. bit like monroe doing intricate brain surgery.
Thank you for everyone's help on the site. Don't have to walk to work next week.
Thank's again steve.
sb37 is offline
#18 Old 11-25-2012
Car thief's aren't "all that". It's not hard getting into any car really as long as you dont care about the alarm going off. Post up what was causing the problem when you get it all working again!
#19 Old 11-25-2012
all that was wrong was the fob lost it's synch to the car. i reprogrammed the fob (2 clicks on fob and put key into ignition and turn to position 2) mechanism seems to work fine.
Need to watch it over next few days though.
steve
sb37 is offline
#20 Old 11-25-2012
That is great!! The forum gets an 'assist'!
Glove Box and Center Console Storage Locked - SLK280 Bob Wilson General Discussion 8 04-26-2012 02:05 AM
Lights blink 3 times when locked dukesbb37 SLK R170 General Discussion 4 02-24-2011 12:37 AM
