Code P0301 - Mercedes Benz SLK Forum
#1 Old 11-06-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Code P0301
Have a friend with an '01 SLK230. She complained about rough running and poor acceleration. Pulled the codes the other day and they came up as 301, 335 and 336. I assume there is supposed to be a "P0" in front of each of those. P0301 is misfire cylinder 1. P0335 and P0336 are both crankshaft position sensor codes. The codes were reset and haven't come back on, but it's also only been a day. What would you think would be the approach to fix this? Plugs have not been changed, so it's due for them I think regardless. Could the MAF cause the P0301 code and it that the likely culprit?
Len
1999 E300D 215,000 miles
sokoloff is offline
#2 Old 11-06-2012
Clean the MAF first, if the codes come back its the CPS. I had the same issue this summer, also when ever i got into the throttle heavy i would get a misfire code and end up in limp mode. The new CPS fixed that issue.
#3 Old 11-07-2012
morpheusRO's Avatar
Vehicle: SLK 200 Kompressor R170 (2002)
What is CPS ?
morpheusRO is offline
#4 Old 11-07-2012
Quoted: 901 Post(s)
CPS (sometimes called CKP) is the crankshaft position sensor, and it's really easy and inexpensive to replace. It usually sits on top of the transmission bell housing. It's a common point of failure.
efair is offline
#5 Old 11-07-2012
Chris_R's Avatar
Vehicle: 2001 SLK 230
Just did the P0301 on my daughter's Volvo C70 convertible. I'm pretty sure it's the same error (misfire on cylinder one). Hers turned out to be that the coil (coil-on-plug) on cylinder one had failed.
To diagnose I swapped coils and plugs around then would pull the connector to the coil (or the plug wire in the case of a car with distributor) while the engine was running. If the engine idle doesn't change then you've found the bad cylinder/coil/plug.
P0301 can also be caused by a vacuum leak, bad/dirty MAF (as mentioned), sticking valve(s), bad rings, etc.
Is the car running poorly?
Chris_R is offline
#6 Old 11-09-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
It was but after a half hour 60 mph jaunt down the freeway with our SLK Group, she said it was running much better.
Len
sokoloff is offline
#7 Old 12-09-2013
Vehicle: 1998 SLK 230 Silver
Other Toys: 2010 950 V-Star Tour
Thanks, I'll order the CPS right now
Eshreeve is offline
#8 Old 12-27-2013
Thanks, I changed out my CPS and the misfire is gone. I can get in to it and it goes
Eshreeve is offline
#9 Old 07-31-2016
Question? I have a po301 when the engine temp is cold. after it reaches 40C an I restart the engine it runs perfect.??
I replaced a couple hoses that were bad figured that would be too easy. I recently did a head gasket and new tensioner unit, hoses bla bla.....
I replaced the MAF sensor unit ordered online new and the top speed issue went away. still once it cools down I need to limp for about 5 minutes...
Any thoughts or could it be cam position sensor at the front of the engine?
Drjake911 is offline
#10 Old 07-31-2016
Quoted: 6490 Post(s)
First please update your location and vehicle (year?: 1996-2017, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
P0123 code - Loss of power in 02 320 twowheelin SLK R170 General Discussion 9 09-10-2017 11:02 PM
Help with a misfire and code P0301 please lombrozo SLK R170 General Discussion 3 08-22-2012 09:22 AM
Code p1230 ? SLKman General Discussion 0 06-01-2010 06:48 AM
Problem with my spare remote kpalmer SLK R171 General Discussion 11 03-15-2010 08:06 AM
