Headlight Help - RH low beam not working - Mercedes Benz SLK Forum
#1 Old 10-04-2012
Vehicle: SLK 230K - 2001
Headlights - need some help - the Right Side (drivers) headlight low bean appears not to be working. When you turn the headlight switch to position one - both side lights come on, when you turn it to position two - the left low beam comes on and the right side stays out. The bulb warning light also comes on at this point. On full beam - both side come on!
Have replaced both H7 bulbs - but get the same problem, have tried swapping the bulbs - just in case - but it works fine when fitted to the left side.
Have checked the fuses in the panel behind the light switch - these are all good...!
What next - I would welcome any advice / guidence.
iNyk is offline
#2 Old 10-04-2012
Quoted: 6492 Post(s)
Thank you,
Moderator/Founding Member
#3 Old 10-10-2012
MidLifeSolution's Avatar
Vehicle: 2004 SLK 320
Other Toys: 2011 Mercedes E350
It is likely your multifunction switch on the steering column. The switch that does high and low bean, left and right signal as well as windshield wipers. I know that was the root cause when both my high beams stopped working.
If you search by my user name "MidLifeSolution", you will find a thread that covers replacing the switch. What the thread doesn't cover is removing the lower dash panel to get at the wiring harness to unplug and plug in the switch.
MidLifeSolution is offline
Tags
failed, headlight, low beam, righthand
DIY - Replace Passenger Side Low Beam Bulb - 2005 SLK 350 grizzlyak SLK R171 Class DIY 13 04-16-2017 02:00 PM
replaced low beam jbanks15 SLK R171 General Discussion 9 02-14-2015 01:26 AM
Slk headlight beam adjuster not working van883 SLK R170 General Discussion 8 11-18-2010 04:27 AM
