Fuse for locks? - Mercedes Benz SLK Forum
  • 1 Post By jonathan
#1 Old 06-30-2012
Donor Conversion
Vehicle: Currently no car, previously Black 32AMG, previously Yellow 230
Chats: 7
Door locks not working (but electrics okay)
Hello Friends
My 2002 SLK32 AMG has stopped working its locks: everything else seems to work properly (windows up and down properly, starts easily, headlights).
So I suspect a fuse for the locks. Anybody got a circuit diagram or know which fuse it might be? Seems there's a main fusebox under the bonnet, one in the side, and one in the boot.
Thanks for all help.
Kind regards,
Jonathan.
Last edited by jonathan; 07-17-2012 at 09:16 AM. Reason: easier to find for people who are looking
jonathan is offline
#2 Old 06-30-2012
Quoted: 6572 Post(s)
Jonathan, try a search for fuse box top right. i will look now
#3 Old 06-30-2012
https://www.slkworld.com/165914-post13.html
#4 Old 06-30-2012
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Check out the PSE pump behind the trim panel in right hand side of the boot. The locks work via a vacuum system, and the area where the pump lives is prone to water ingress, leading to the pump failing.
Woolly is offline
#5 Old 06-30-2012
Donor Conversion
Chats: 7
... thanks Jeff. I checked all the fuses in main and behind lighting switch: all okay.
... thanks Woolly ... I'll check that out now.
Kind regards,
Jonathan
jonathan is offline
#6 Old 06-30-2012
Donor Conversion
Chats: 7
Sounds promising Woolly ... I took a look but didn't really know what I was looking for or how much panel to remove so I gave up for the day ... I'll search around for some pictures now.
And I couldn't even find the fusebox in the middle pictures here:
http://www.buellwinkle.com/r170/images/FuseLoca.gif
Thanks for the tip though. I'll fight it again tomorrow.
Jonathan.
jonathan is offline
#7 Old 06-30-2012
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by jonathan View Post
... I took a look but didn't really know what I was looking for or how much panel to remove . . .
Clicky HERE.
Woolly is offline
#8 Old 07-11-2012
Vehicle: best investment ive made so far
Other Toys: Golf MK3 VR6
Are you trying to open the car using your remote? Maybe the key needs to be re-synced. Another fun trick i picked up on thanks to slk world is to check the PSE pump, Blow in the pipes and watch your doors unlock atleast you'll know if you have a blockage or a pipe not feeding air. anyway good luck
JustinArends is offline
#9 Old 07-16-2012
Donor Conversion
Chats: 7
Hi Woolly
... where the pump lives is prone to water ingress ...
Full marks! See attached nastiness of the corrosion of my circuit board. I ended up with the garage replacing mine.
For what it's worth, the car works perfectly well without this in. You just have to unlock manually (driver's door and boot have keyholes, petrol cover done by hand just inside the boot, passenger door from inside) and the remote control still does the alarm. I didn't find out how to open the central console box without this.
If anyone is taking one of these apart: you need to gently prise the lid off with lots of small levers (eg screwdrivers) but don't unscrew anything. Lift the cover straight off, as it has legs which hold the rubber-mounted pump in place. Inside is the circuit board, which is attached only by two cables to the pump itself and a solenoid (rather short), and by the top of the suction sensor which is a snug fit into the white plastic housing of the pneumatics. The star-screws attach the pneumatics to the black housing.
Above is about an R170: 2002 SLK 32AMG. Don't know about the other models.
Thanks for advice, perhaps my notes will help someone whose pump isn't as badly corroded.
Kind regards,
Jonathan.
Woolly likes this.
jonathan is offline
#10 Old 07-16-2012
MrG
Vehicle: Black '02 SLK320
When my locks quit working along with the dome light and trunk light, fuse number 9 in the engine compartment was the culprit.
MrG is offline
#11 Old 07-16-2012
leapyfish's Avatar
You should have a look at your rear drain to make sure its not plugged up & cause this problem again
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#12 Old 07-17-2012
Donor Conversion
Chats: 7
thanks Mr G that's a good thing to check for the next person with this problem
thanks leapy will certainly check this.
Kind regards,
Jonathan.
jonathan is offline
R171 Fuse Allocation Chart Puffin Where to get R171 SLK Items 34 05-22-2018 04:48 PM
SmartTop Roof module Install for the R171 etyu SLK R171 Class DIY 13 09-29-2017 09:49 PM
"secret fuse box" Radiator Fan Fuse- What amps? Arachnyd SLK R170 General Discussion 0 04-07-2012 08:34 AM
location of fuse for interior fan jsc6546 SLK R170 General Discussion 7 08-04-2011 10:17 PM
