strange manual gearbox noise - Mercedes Benz SLK Forum
#1 Old 06-12-2012
murat orhan's Avatar
Quoted: 29 Post(s)
My 2000 slk 200 kompressor 6 speed manual started making a strange noise recently. It only happens while the car is coasting about 15-20 kmph, 2nd gear selected and clutch fully depressed (usually just before you come to a full stop at the lights.) If you put the stick in neutral the noise is gone and back again in 2nd. It a kind of knock-knock noise depends on speed, comes from engine bay. Sometimes every audible sometimes not, but always there. Except the noise, shifting works fine as usual. I renewed the tranny oil aprrox. 1 year ago with the original. The car is at 60.000 miles.
Any experience or opinions?
Is it an easy fix?
murat orhan is offline
#2 Old 06-12-2012
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
It could well be a worn thrust/release bearing. Do you make a habit of riding the clutch/coasting with it in gear - not a good habit to have.
The good news is, it can go for quite a while before it causes serious problems, usually indicated by the noise getting worse.
To fix it, you have to separate the transmission from the engine, I'm not sure on your engine whether it would be an engine or transmission out job, or there would be enough room to just disconnect the prop shaft and slide the gearbox back a bit. If you do have to remove the engine or transmission, then I would renew the clutch whilst you're in there - the parts are cheap, the main cost is the labour charges in stripping down/rebuilding.
Woolly is offline
Tags
manual gearbox
What Auto Gearbox Mode do you use ? Comfort, Sport or Manual tonywilde SLK R171 General Discussion 56 02-12-2013 03:50 AM
Strange engine noise lowhumor AMGs 5 03-31-2010 01:27 PM
