Water sloshing in the side panels - Mercedes Benz SLK Forum
  • 2 Post By Airmousam
#1 Old 05-30-2012
Airmousam's Avatar
Vehicle: 1999 SLK gone....2007 CLK550 & 2010 E550, now looking for a SLK55
Other Toys: 2009 Suzuki M109R
Heres a weird one that i could not find in my searching. On my r170 water and i mean a lot of water is finding its way behind the black side panels under the doors. I can hear when im stop and go. I pull the 2 plugs for the jack, and a few hard stop and starts, and im getting a gallon or 2 out. Happening after i drive in the rain. Any ideas? Thanks
Airmousam is offline
#2 Old 05-31-2012
First i've heard of that problem, check the drains to see if they are clogged.
#3 Old 05-31-2012
Vehicle: 1999 slk 230
Quoted: 526 Post(s)
Have 2 agree with live free. Clogged Drains a common Problem on all Mb. Dating back 2 1959. Not alot Mb Drivers pay at attention 2 it. Twice a Year check them Plugs. Remember them Mbs W 108 114 115 116 123 you lift up the Rubber Mat in the Trunk and you see Rust. Yep clooged Plugs...
Berliner Heckflosse is online now
#4 Old 05-31-2012
Vehicle: SLK R171 200k 2005
In addition, you could check the outer seals of the side windows (where the windows slide down). Those seals wear out and water starts dripping inside the door frame, especially on cheaper brands...
SamuraiSpirit is offline
#5 Old 05-31-2012
Airmousam's Avatar
Thanks for the replies guys. There was a slight amount of dirt on the plugs but not much. First time i noticed this, i used a hose a blasted water in there to flush it out, drove with hard stops with plugs removedHow and where does this water get in? Cleaned the plugs with hot water and put them back in.. Talking a gallon or more in there... Window seals look tight, and the doors are not connected to where this water is... Thx
#6 Old 05-31-2012
Can you please take a picture of the panels.I suppose you have checked the drain plugs in front of the wind shield. However, I assume that the guys are talking about the plugs which are situated under the fitted carpet under your floor mats. You should remove the carpet and check below. Just be careful with the removal. However, water can leak from there only if you are driving over puddles and in that case, the carpet will be wet as well... It could also drip from the side of the doors where the hinges are situated if the door is slightly misaligned.
You can also pour water from a bottle into the drain plugs in front of the wind shield and look under the car to see how much of that water is going to leak on the ground.
The Following User Says Thank You to SamuraiSpirit For This Useful Post:
#7 Old 06-03-2012
Airmousam's Avatar
Plot thickens, got 5" of rain yesterday, driver side floor soaked
#8 Old 06-03-2012
Airmousam's Avatar
All 4 drains appear to be working, but i had a couple gallons of water on the drivers side floor. Pulled the 2 plugs on the drivers side side panels and did a few hard stops water was puring out. Crazy, im stumped
#9 Old 06-03-2012
Airmousam's Avatar
Figured it out!!!!!!!!!! There is a large rubber plug with an angled outlet just forward of the rear tire next to the hard rubber bumper. Pulled that and holy cow did water pour out, prob 2 gallons. It was clogged with crap. Cleaned and replaced. Other side was also cleaned but no water. Now i have to get the seat out and dry the carpet. Whew!!!!!!!!
Der Flieger and SamuraiSpirit like this.
The Following User Says Thank You to Airmousam For This Useful Post:
#10 Old 06-03-2012
leapyfish's Avatar
Could you post some pics of the plug & outlet, please
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#11 Old 06-10-2012
I agree can u snap a quick pic of the drain your talking about? Thanks
Klonny is offline
#12 Old 06-11-2012
Airmousam's Avatar
Car is in the shop getting the carpet replaced. Will take pics when i get it back. Basically just foward of the rear tire next to the hard rubber bumper. Cant miss iit, soft rubber with an angled outlet. Pop it out clean it and replace it. Thx
Front side markers, remove/replace procedure etyu SLK R171 Class DIY 90 05-18-2017 03:23 PM
Three Problems - Water sloshing, Grinding on gear change, MPG readout pbsd SLK R171 General Discussion 9 09-04-2011 05:50 PM
Part # for push clips that hold the rear side panels? atebit R230 SL 4 12-26-2009 02:55 AM
Water leaked into side lense toySLK SLK R171 General Discussion 4 04-25-2009 09:29 PM
Water coming out the pass side compartment hawkgt SLK R171 General Discussion 6 08-07-2008 05:00 PM
