230k roof not working (please help) - Mercedes Benz SLK Forum
#1 Old 05-26-2012
Vehicle: Mercedes Slk 230k
Other Toys: Audi S8
Hi everyone, i am new to the forum so i may ask questions which have already been covered. Sorry in advance.
I recently bought a 2001 SLK230K but the roof is not working, i can hear the motor working but nothing happens. The roof slight moves as if its straining but nothing, The windows dont go down either. I dont know if this is related but the electric seats have stopped working but do sometimes when i hit bump . Any help would be appreciated, the hydraulic fluid is just in between the two lines and i haven't come across any leaks.
Thank you in advance.
badmaash is offline
#2 Old 05-26-2012
Quoted: 6558 Post(s)
Thank you,
Moderator/Founding Member
#3 Old 05-26-2012
Originally Posted by badmaash View Post
. . . i can hear the motor working but nothing happens. The roof slight moves as if its straining but nothing, . . .
All things being equal, when you pull the roof switch back, three things start to happen all at the same time.
1a) the windows go down,
1b) the roof unlatches,
1c) the trunk lid opens.
Only then does the system continue to where the roof starts to physically fold back/retracts.
Nothing else should happen unless these first three operations are confirmed by their limit switches. So if the quarters are not going down, the roof will not fold back. So my suggestion here would be to make sure the switches are changing state. (Particularly with what ever controls the quarter windows.)
Sorry, I don't have an easy way to do this, I've never had any issue with my switches. The roof latch switches shouldn't be too hard to check, but you will need to remove the headliner to get to them; if you are willing ro undo some of the wire bundles in the trunk, all the switch wires eventually wind up back near the pump. I would suspect that there is a connector you can check there, but you still might have to remove some of the panels. Some of the other folks here have had more experience with the electronics. (My area is more the mechanics.)
Hope that helps . . .
lilred320SLK is offline
#4 Old 05-27-2012
leapyfish's Avatar
If the windows do not go down thats one problem, do they work at all?
theres a switch in the trunk Roof Closed Limit Switch
Hers a troubleshoothing guide Vario Roof Troubleshooting Guide
Top Operation
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#5 Old 05-27-2012
Other Toys: Audi S8
Thank you for the replies. The windows work perfectly normal. When I press the switch all I hear Is the motor and the roof squats slightly. The electric seats are not working but I don't think that should be related.
badmaash is offline
#6 Old 05-28-2012
Vehicle: 2001 SLK 320
I bet your roof top cylinder is sticking or needs a rebuilt. Manually unlock the roof top and see what happens then.
When my top cylinder needed repair, nothing else would open (windows, trunk, etc(.
Option 2: Did you check to make sure the roof wasn't manually closed before? Check to be sure the air release valve screw on the pump is tight.
You could also have a broken switch behind the right roof cylinder. This would make the roof think its in a different position than it is. a partial manual open may help identify the culrprit. Good luck!
Arachnyd is offline
Roof not working ! SLK32Love General Discussion 3 05-13-2011 01:31 PM
slk230 Drivers Window and roof not working PPK SLK R170 General Discussion 4 05-02-2011 03:56 PM
Zaino and Vario Roof module working in tandem mcat SLK R171 General Discussion 23 10-03-2006 02:10 PM
