roof / supercharger problems - Mercedes Benz SLK Forum
#1 Old 05-23-2012
Vehicle: 230 and 350 slk
FIRST PROBLEM The roof on my 1997 230 slk has been fine but today when i have put it down the boot will open and the windows will go down but the roof will not ! but after trying 10 or 20 times it works ok for about 5 times and then the roof section will not fold away again. When it does this i can still hear the motor(pump ) running but the roof will not come down. Any One had the same problem ? What was the Fix ?
SECOND PROBLEM The clutch on the supercharger has become noisy when engaging around 1500 rpm. As soon you rev the engine to 1500 rpm it engages the supercharger with a click and then i can hear a bearing type noise untill the rpm drop below 1500 when it disconnects and all is quiet again. Can this clutch be lubricated with oil or will this cause the clutch to slip ? Or is this normal ?
Tim
performance is offline
#2 Old 05-23-2012
leapyfish's Avatar
1st problem,
It may be a wire that is frayed/damaged that goes into the roof, heres one story https://www.slkworld.com/ask-dansslk/...lf-way-up.html do a search to find more info.
2nd problem,
I thought the supercharger engages at 2500 rpm.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#3 Old 05-24-2012
Vehicle: 1999 SLK230
Problem 2
Get a supercharger bearing on Ebay. One seller sells them for about $40. The other guys are over priced. The bearing is a common problem because they do not last long. It will require snap ring pliers to change. While your at it check the oil in the supercharger. I use full synthetic gear oil Mobil 1. I have had many vehicles with Eaton based superchargers, that is the oil to use.
lowflyingbird is offline
#4 Old 06-04-2012
Vehicle: 2005 AMG SLK 55 - currently for sale
Other Toys: 2011 Mustang, Ford F-150 lightning, Hilux 2.8 V6, CRV, Aprilia RSV Millie
Quoted: 17 Post(s)
With the roof, check the wiring around the rear window to roof sections as that was my fault.
For the S/C issues, have you got links to the correct bits. Mine is a bit noisy and would like to change the oil as well.
Marct is offline
#5 Old 06-06-2012
Vehicle: 2001 SLK 230 Kompressor
Other Toys: 1984 Mustang 5.0 HO, 2007 Harley Electra Glide Classic, 2016 F250 4x4, 2014 Ford Explorer XLT
https://www.slkworld.com/slk-r170-cla...tml#post306809
This may help with the roof. Sounds like the same problem I had. Mine hasn't failed me yet. Hopefully it isn't much more than some WD 40.
SSMOKEE is offline
More Roof problems... dcalland SLK R170 General Discussion 15 04-15-2012 06:58 PM
New member with Supercharger problems Ken Thompson New Members Introduce Yourself Here 18 02-07-2010 10:46 AM
Hot Weather roof problems nickbeckett SLK R170 General Discussion 7 07-11-2009 06:38 PM
