Cylinder not firing (dont think its a coil issue) - Mercedes Benz SLK Forum
#1 Old 05-23-2012
Vehicle: 98 SLK 230 Kompressor
Other Toys: 05 Discovery 3 HSE, 73 Rover P6 3500s, 78 Dateline Bikini
Hi, hope someone can help me! I have a 98 SLK 230K. the forward most cylinder (not sure which number it is) has decided to stop firing. I was overtaking someone and it suddenly started firing on 3 clylinders.
I swapped over the coil packs to try and eliminate this, it made no difference to the fact the forward cylinder wouldn't fire. Also I had the engine running and removed the HT lead from the plug and it was earthing when it touched the cylinder head so there was definately a spark there.
The spark plugs are also less than a year old.
MAF sensor is a cheapy one but quite new.
Are there any other common causes that would stop a cylinder firing. I realy hope it is nothing serious!
Any hints would be much apreciated
grahamk is offline
#2 Old 05-23-2012
Quoted: 6558 Post(s)
moving to r170 general discussion
In addition, if you haven’t, please post your question in the appropriate discussion forum for a quicker response. Be patient and a knowledgeable member will address your question.
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
#3 Old 05-23-2012
PMB
Vehicle: SLK320
Other Toys: 2006 Mini Cooper, 1981 Yamaha RD250LC, 1996 Suzuki Bandit 600, Motobecane AV92 (being restored).
When you removed the plug lead did you remove and test the plug? When plugs go it is usually sudden.
PMB is offline
The Following User Says Thank You to PMB For This Useful Post:
#4 Old 05-23-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Pull the plug....
FUN 4 2
Der Flieger is offline
#5 Old 05-23-2012
I haven't removed the plug yet as I didn't have the tools available at the time. The car is now sitting outside my house and I am sat on an oil rig for 2 weeks. I didn't suspect the plug as it was less than a year old. There were no horrific sounding noises from the engine when It was firing on 3 cylinders.
Will pull it when I get back, if it is that I will be over the moon!
grahamk is offline
#6 Old 05-23-2012
Vehicle: 2002 SLK 230
Other Toys: 95 corvette , 67 camaro RS , 3 MGA , MGB , 1953 studebaker coupe ex saltflat racer ,
If the plug checks ok it may be the fuel injector as it will give the same sympton's .
WaterBug is offline
The Following User Says Thank You to WaterBug For This Useful Post:
#7 Old 05-23-2012
Quoted: 914 Post(s)
Definitely check the plug, and also the fuel injector as well. The plug is the more likely to fail. I don't know your engine but in general the injector will have two wires, one will be constant +12V, the other will be to ground via the Motronic. (The idea is the Motronic will ground the injector briefly during each intake stroke to inject fuel, the longer it's grounded the more fuel's injected). So, disconnect the injector electrical leads and check for +12V on one of the wires. If you have an electrical meter that can measure duty cycle, that might be good value to compare as well. Compare the cylinders to each other and post back your results.
efair is online now
#8 Old 06-08-2012
Hi all, well...been tinkering with the car all day with no joy, here is what I have tried.
Changed plugs
New plug leads
Swapped coil packs about
Replaced maf sensor
2 replacement injectors
Compression tests are all good
Faults showing up on little diagnostics are multiple misfires, one for each cylinder, definitely only one cylinder not firing,
Help! I'm seriously stuck... Only thing I can think of now is a broken rocker arm?
grahamk is offline
#9 Old 06-09-2012
Quoted: 914 Post(s)
Were you able to test the injector voltages per my last post?
efair is online now
#10 Old 06-10-2012
Oops forgot to mention in my last post, I checked these two and everything seemed ok with them, all 4 giving good readings...totally baffled as to what it could be...hope the engine is not terminally damaged
grahamk is offline
#11 Old 06-10-2012
Quoted: 914 Post(s)
Does it misbehave at idle, or only at higher RPM/load?
Did you replace your AMM before or after the misfires started? (I've seen cheap AMM's give all kinds of problems).
If it's due, I might go ahead and replace the fuel filter proactively. Then I'd measure the fuel pressure.
efair is online now
Some tips and tricks for convertible top cylinder rebuilds Arachnyd SLK R170 class DIY 58 08-25-2018 08:37 AM
Question for those who know their misfires... poohlikeshunny SLK R170 General Discussion 17 05-16-2018 02:40 PM
r170 top cylinder replacement help!! murat orhan SLK R170 General Discussion 5 03-09-2012 11:21 AM
Noise/rattle from excessive hydraulic cylinder play? hummingslk SLK R171 General Discussion 4 09-27-2011 06:59 PM
Ignition Coil Primary Circuit Condition #2 coil darkyvader SLK R171 General Discussion 5 08-28-2010 06:45 AM
