Raining Inside :( - Mercedes Benz SLK Forum
#1 Old 05-11-2012
Vehicle: 230K
Other Toys: Bang and Olufsen
Chats: 7
Raining Inside :(
Hello All
Im sure this is a old question but i need help with my R170
ever since i have had it when it rains a little but of water comes through the seal where they join above the drivers window.
this week we had loads of rain and im not sure if its realted but the roof is closed fully and when driving water kept pouring out from the interior ligth fitting.
its getting in somewhere
is this common and if so what is the fix for this.
Cheers All
Seanie_230 is offline
#2 Old 05-11-2012
Quoted: 6547 Post(s)
yes, it has been covered before. have you tried a 'search' top right?
here is one hit from search:
https://www.slkworld.com/slk-r170-gen...oof-leaks.html
#3 Old 05-11-2012
Vehicle: SLK R171 200k 2005
With the engine running, operate the roof mechanism and stop it halfway. Carefully examine all seals, they should be intact. Also check the seals of the rear window.
Also check if the roof is misaligned. On the R171's roof, there are small marks on both sides where the roof meets the windshield frame when closed. If the roof is aligned, there should be only one primary mark on each side. Hope I am clear enough.
With the roof closed, check whether the side windows fit into the upper seals.
If everything looks intact, there is no need to worry for the leaks, the raindrops won't damage anything.
It is a complicated mechanism and some drops inside are possible. The atmospheric conditions also affect the seals' elasticity (heat, cold, humidity, dryness).
If you are using jet wash for your car, you will see that sometimes a few drops enter the cabin, sometimes don't, depending on the weather conditions.
SamuraiSpirit is offline
The Following User Says Thank You to SamuraiSpirit For This Useful Post:
Inside frt. Tire wear DEEDUBYA MCMILLAN Tires, Wheels, Brakes & Suspension 5 05-06-2012 02:58 PM
SWOOON! Z4 has new Yellow inside & out... RacerCub68 Off Topic 8 06-08-2011 10:20 PM
Wiring from engine bay to inside dashboard ghostdunks SLK R171 General Discussion 1 12-20-2009 05:30 AM
Smoke the rear windscreen. Inside or outside? Daniele General Modifications R171 17 02-15-2008 01:56 PM
