Exhaust manifold replacement help! - Mercedes Benz SLK Forum
#1 Old 05-07-2012
Vehicle: 2001 SLK 230
I have a 2001 slk 230 that has a crack in the exhaust manifold. Does anyone have a step by step directions for removal of the manifold. I appreciate any help. I do not want to remove more than what is required to get it off for welding.
copter17 is offline
#2 Old 05-07-2012
Quoted: 6539 Post(s)
Moving to r170 general discussion
Thank you,
Moderator/Founding Member
#3 Old 05-07-2012
Welcome from New Hampshire. I don't recall a step by step DIY but i do know the job will go faster if you remove the SC.
#4 Old 05-07-2012
Vehicle: 1999 SLK230
If your in need.....
I just did an engine swap, and I have an extra one. I can double check it for cracks, didn't know it was a issue with these. I know sometimes exhaust manifolds after years of use do not weld nice (sometimes).
lowflyingbird is offline
#5 Old 05-08-2012
Livefreeordie I'm not sure what you mean by the SC (turbocharger)? And how hard is that to takeoff. Remove the whole item or just the top half? Low flying bird I might be interested. I won't be able to get back to working on it tell the end of the week. I don't want to take apart more than I need to to get her out.
copter17 is offline
#6 Old 05-08-2012
Super charger. You have to remove all air intake related items that are in the way, remove the belts. Disconnect and remove the air intake manifold then you can get to the S/C. You should only have to remove the S/C, the bracket it mounts to can stay. There are gaskets involved so careful not to damage them.
#7 Old 07-01-2012
Vehicle: Slk230K '00
I may have some useful picture when i replaced my broken exhaust manifold. I can only managed to removed the exhaust manifold by removing the top of supercharger. You need to jack up your car to removed the bottom nut of the manifold. Here it is
after removed filter and top of supercharger
the flange connection with part of the broken manifold attached
my broken manifold
Star Key(torx) is needed
Michaellu88 is offline
#8 Old 07-02-2012
Thanks for the photo's. I finally figured her out and got her done.
copter17 is offline
#9 Old 07-02-2012
Get er done!!
#10 Old 07-02-2012
I did a complete Super Sprint header and exhaust system installation on Steve Johnson 2001 Slk230 about 8 years ago. I did post alot of pics on Benzworld forum. Try doing a search over there. It not hard once you removed the SC and exhaust manifold heatshield. Even though you can't see all the exhaust manifold nuts but uou can feel it with your fingers and put a sockets on it to remove.
Klinh is offline
#11 Old 12-22-2013
Vehicle: 2000 SLK 230 Sport
Other Toys: Yes (cars, bike)
Hi all!
Has anyone in use the one listed here:
http://www.ebay.com/itm/360579230547...84.m1423.l2649
And if so, what is the feeling of the car with such?
Thanks,
Adrian
ITAdrian is offline
SLK55 AMG exhaust options 009 AMGs 12 12-14-2016 11:26 AM
DIY: SLK55 R171, Exhaust Manifold Removal, Repair, Replacement lebmingling SLK R171 Class DIY 10 02-26-2012 02:21 AM
exhaust manifold msgtal SLK Parts For Sale 3 10-05-2011 02:13 PM
Anyone know about exhaust manifold ? beanie SLK R170 General Discussion 6 03-29-2010 12:30 PM
