1999 SLK230 duovalve replacement - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By sokoloff
  • 2 Post By shadetree
#1 Old 05-02-2012
Vehicle: 1999 SLK230 Kompressor
After some intermittent issues with my passenger side vents blowing only hot air, my research led me to check out the duovalve. I pulled it apart and cleaned it up a bit, and it seemed to fix the problem for about a day or so, but now it's coming back. I know it isn't an electrical issue because I tested the voltage on the power cable and it seems fine. So my conclusion is that the valve itself is failing - either one of the pistons is sticking, or one of the coils is failing.
Now, I'm prepared to replace the valve, but figured I'd hop on here first and see if anyone else has any experience buying one of these. I've found them through a couple of online suppliers for around $230 or so, made by OES Genuine. Is there anyplace that might stock them a bit cheaper or refurbished, or is there another manufacturer of these? The two places I found it are autopartswarehouse.com and partsgeek.com. Any experiences with either of them? Finally, do you agree with my conclusion that the valve needs to be replaced, or is there something else I might be missing?
HounDawg07 is offline
#2 Old 05-03-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Are you sure that your r134a level is correct? On some Mercedes, different temperature levels can be a sign of low refrigerant level. It could also be the duovalve, but I wouldn't throw parts at the problem until you are positive that's the issue.
Len
curro101 likes this.
Len
1999 E300D 215,000 miles
sokoloff is offline
#3 Old 05-03-2012
Gulliver's Avatar
Vehicle: '99 R170 SLK230 Kompressor
Other Toys: S55 AMG, lots of old GM muscle
Good advice from Sokoloff..
I have used partsgeek many times, with good success. However, I did recently get front axle seals for the S55 AMG sedan from them (they have the speed sensor 'fan' built in.) Though they said they'd fit my car, and looked good/correct, our AMG couldn't read them.. I had to disassemble the calipers/rotors etc. a second time to replace with oem, which of course did fix it. No word yet on a refund..
Gulliver is offline
#4 Old 05-03-2012
don't give up on the DuoValve yet...
It took me 2 tries to fix the same problem. I ended up doing the same thing, pulled the metal pistons, wiped them clean and put them back in. It worked for a week then no luck.
then I pulled them out again and used steelwool to make them nice and shiny, that was a month ago and so far so good!
I suggest you pull it apart again one more time (it's like 2 bolts that takes 5 minutes tops!) and make them nice and shiny! much better than a couple hundred bucks on a that part.
Klonny is offline
#5 Old 05-03-2012
Thanks for the advice. I'll have to check the refigerant level when I get a chance, but I'm pretty confident that it's the duovalve, considering that it started working perfectly as soon as I cleaned and reassembled it.
Klonny: good point, it's probably worth making another attempt at cleaning it again, especially that it will be easy to pull apart now that I know how to do it. I did hit it with the steel wool last time but maybe didn't clean it well enough. At least the weather has been nice this week so I have been able to keep the top down and not worry too much about the air vents
#6 Old 05-06-2012
So yesterday I was out and about all day, and it started working normally for a bit... and then just as suddenly went back to blowing hot air.
Anyways, I took it apart again today, cleaned it all out again, polished up the pistons, etc. and no luck. I should note that even the first time I pulled it apart, it looked pretty clean. Maybe a little residue of some sort but certainly wasn't gunked up. I'm not sure at this point that it could be anything other than a piston sticking or a solenoid failing. I did notice that on one of the pistons it appears that the outer metal coating has chipped off in a couple places. Very tiny, but it may be enough to make it catch. Probably gonna go ahead and buy the part but I'll give it a little time and see if anyone else has any other input.
#7 Old 05-06-2012
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
It could also be a wire in a coil is broken so it wouldn't matter how clean you get it ! You might want to think about trying a used part !
Mercedes SLK-Class W170 Heater Hot Water Valve 1147412114 0018307784 A0018307784 | eBay
curro101 is offline
#8 Old 05-10-2012
UPDATE:
@curro101, I think you nailed it. I did a continuity test on the metal prongs. Closed loop on the right, open loop on the left. Apparently something wasn't making a connection, or at least only was intermittently.
I went ahead and bought the part new through PartsGeek ($225). I was too wary to buy used. Swapped it out today and took it for a ride and everything seems to be working perfectly. I could tell when I compared side by side that the coils in the old one looked pretty well used.
#9 Old 05-11-2012
curro101's Avatar
Quoted: 528 Post(s)
Glad you've got it working !
curro101 is offline
#10 Old 06-12-2012
Vehicle: 99 SLK 230 AMG SPORT
how long does it take to install duovavle
How long does the duovalve take to install?
My warranty company and the dealer have about a 90 minute discrepancy in labor time which they both want to pass the cost on to me. I think the warranty company is right though. 1.8 hours should be enough to put this on.
rocc_Diesel is offline
#11 Old 06-12-2012
Even that seems pretty generous. It only took me maybe 15 minutes or so, and I'm far from being a mechanic. Granted, I didn't replace it entirely; I just disassembled the old one and replaced all of the moving parts (pistons, coils, etc) so that all that was left of the old one was the plastic base. I wasn't sure whether I would have needed to drain the coolant before detaching the hoses, and there was a rubber grommet holding it in place that seemed like it would be a pain to get off, but I still can't imagine it would take that much longer.
How long did the dealer bill for?
#12 Old 07-02-2013
Vehicle: 00' SLK 230 Copper Designo
FYI for any future readers.
If the wires break on the coils inside the duovalve, chances are they can be repaired by soldering them back together. Had I thought of it at the time, I'd have taken pictures.
My duovalve first blew maybe around 2004. Back then I checked it and sure enough, only one side was working. I pulled it apart and I unsoldered the broken coil inside, unspooled one circle worth of wire, repairing the broken/short wire. I snipped and soldered the thing back together. It worked flawlessly until last week when I repeated the performance. This time I also polished the pistons as they were getting a little messy looking.
It works like a champ once more!
I guess i'm only saving around 50-60 dollars as there are tons of em on ebay now.
search "Valve 1147412114 0018307784 ". Back in the day it was several hundred dollars and a kiss on the cheek from mercedes. I decided to just go ahead and fix it again this time since I had done it before. Fortunately once I got a little wire and was able to test, I had the same ohm reading on both coils. (if one is really far off, it could be a sign that the coil is burned up)
Note: this requires soldering very fine wires in very little space. if you're not that good at soldering, i'd suggest finding someone who would do it for you. Also, when soldering/testing the wires, use a lighter to burn the varnish/invisible insulator off of the ends of the wires. when i tested the coil i believe i got around .02 ohms that showed it was good.
JaysonM and M4rCu5 like this.
shadetree is offline
Transmission / torque convertor issues??? SLK230 1999 WhyBeGood SLK R170 General Discussion 13 09-11-2015 07:04 PM
1999 SLK230 Sport Red Automatic 65,000 $8,000 nautiquelfe SLK Cars For Sale 6 08-09-2012 06:48 AM
FS: 1999 SLK230 Manual, So. Cal. Todd157k SLK Cars For Sale 4 01-16-2012 03:07 PM
1999 SLK230 Kompressor White Sport Pkg AaronHartwell SLK Cars For Sale 4 01-02-2012 08:36 PM
Considering a 1999 SLK230 Craigmri New Members Introduce Yourself Here 17 07-24-2011 10:01 PM
