Switching 17in for 16in - Mercedes Benz SLK Forum
#1 Old 05-01-2012
Vehicle: 2 1999 SLK 230's Red/Black
Other Toys: 3series BMW/Jeep GC
I have a 99230SLK with the Sports pkg. AMG 17"wheels/rims. I met another SLK driver, with the 16" wheels/rims, that I think were standard.
Pic in link.
Mercedes Benz SLK230 Used Car Pricing, Financing and Trade In Value
I liked his, & were talking of trading. My BF says bad idea, smaller wheels worse for resale. True? Is this simply a matter of personal taste? Any thoughts on this?
Does it affect the ride with the smaller wheels? I assume the 16 have the same bolt pattern (i should prob check...)
LoisLaneCA is offline
#2 Old 05-01-2012
Originally Posted by LoisLaneCA View Post
.... My BF says bad idea, smaller wheels worse for resale. True? Is this simply a matter of personal taste? Any thoughts on this?
1. BF is right about resale.
Question is: why do you want to switch from 17" to 16" rims? It may be the sports package has a stiffer suspension. Perhaps have someone double check on the integrity of your current suspension set-up.
2. Between R170's and R171's, the bolt pattern is the same.
3. Ride is softer, like a limousine, on the 16"
#3 Old 05-01-2012
Quoted: 6545 Post(s)
bad idea in my opinion, yes
affect ride, definately, plus mileage will go down (wheels have to turn more)
#4 Old 05-01-2012
Aesthetically pleasing purposes, only
Thank, guys.
I like the look of the 16in better. No reason as far as the suspension, ride... I think his wheels are prettier. (Don't shoot, I am still a girl, i just have 4 cars.....)
My AMG wheels look like crap, they are peeling around the MB symbol. His look good...
The guy I am talking to about switching has called me 4 times, so I assume that cost wise, it is in his favor, right?
#5 Old 05-01-2012
Yes.
You can always have your current rims re-finished or powder-coated (and to a colour and finish of your choice to boot).
#6 Old 05-01-2012
is the other driver a member of this forum? why not?
#7 Old 05-01-2012
leapyfish's Avatar
The brakes on the AMG models are made for 17" or larger rims & a 16" rim will not fit over them.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#8 Old 05-01-2012
Good point
#9 Old 05-02-2012
We are talking about the 230 SLK w/ sports pack, right?
Crap, I was wondering about that! Wonder why the Marine BF didn't think of that?
#10 Old 05-02-2012
I'll respectfully suggest that, as to mileage in particular, I think you are addressing if the outer diameter (OD)/circumference of the tire changes, not the wheel (rim) diameter.
And even that isn't always true. Your speedo essentially counts revs/time, with a smaller tire; it will take more revs to go from A to B - but your odometer will tell you that you went further than you previously did and it would take you more time to boot. (If you keep your speedo on the same "speed" before and after.)
So doing the calculation from the information the car is giving you is problematic.
To be very precise, you’d need to measure the performance of the car from outside; or at least to compare a before and after performance over a distance you are familiar with or can independently determine.
If you were timing the car from the outside, a smaller tire outer diameter would be like installing a slightly "higher" performance final gear in the car. But given everything else, I'd say nominally there would only be small "efficiency" type differences.
The total energy the car expends is based on the equation, Work = Force X Distance, and those are remaining constant. (More of a factor would be where the car runs most efficiently - engine speed, mechanical & aero drag, etc. - and a tire size change could effect that positively or negatively depend on the actual car variables.)
Math aside . . . . Generally I like to "see" larger OD tires on a car since they "fill up" the wheel wells just that little bit better.
(Though they obviously have to fit over the wheel workings (brakes, joints, etc.) regardless.)
lilred320SLK is offline
#11 Old 05-02-2012
320 dreamer's Avatar
Chats: 5
the 230 had the same brakes no matter the package. the only amg in the r170 was the slk32. the sport pkg is for cosmetics only
320 dreamer is offline
#12 Old 05-02-2012
leapyfish's Avatar
My mistake
Headlight Switching microbe SLK R171 General Discussion 9 03-18-2014 03:58 AM
Thinking about switching from a 06 BMW Z4M to an 05+ SLK55. Convince me brandobot AMGs 40 03-20-2012 01:05 AM
Switching to Kanada "mode" Der Flieger SLK R171 General Discussion 2 09-29-2011 06:57 PM
FS Continental Contact Sport DWS 17in slk350wdc SLK Parts For Sale 7 06-28-2011 02:42 PM
Switching Radio Reception from US to Europe standard Passie1979 SLK R171 General Discussion 4 08-25-2010 04:35 PM
