Misfire at high rpm no load - Mercedes Benz SLK Forum
#1 Old 04-22-2012
Hi all,
Yesterday I noticed a stutter/misfire in my '98 230 (MT) at high rpms (~>3,500) but only seems to occur when revving with clutch depressed. It accelerates fine through the gears both under light and high load.
I have a slightly instable idle and occasionaly the s/c clutch engages at idle even if the engine is warm and stays on for no more than 2-5 secs then disengages with a following short drop in idle rpm. No other engine misbehaviour noticed.
I will proceed to check the K40, MAF and spark plugs now - anyone has any other ideas?
Will appreciate your input, thanks in advance.
Raindog
Raindog is offline
#2 Old 04-22-2012
Update:
Just soldered the K40. It was not nearly as bad as the pics in Bazzles sticky on the topic, but quite a few of the solderings were cracked and needed resoldering.
However, it did not solve the misfiring which still remains. I noticed though that it is only there when the car is at a standstill. When at speed, I can depress the clutch and rev the engine beyond the 4,000 rpm where the misfiring otherwise occurs
Anyone dares a guess at what could possibly cause the described symptoms?
Raindog
Raindog is offline
#3 Old 04-22-2012
Red face rpm limitation
Ok. Did a more thorough search in past posts and found that the engine has a rev limitation around 4,000 rpm when at standstill. Sorry for not finding this prior to my two previous posts.
I must say though that the actual limitation is far from smooth and certainly does not feel intended - It had me fooled thinking that something was wrong.
I guess this is another reminder that these supercharged engines are not intended for high revs. I love it for the low rev torque though and I am happy that what I thought was a problem turned out not to be.
Hats off to these forums and past posts
Raindog
Raindog is offline
The Following User Says Thank You to Raindog For This Useful Post:
#4 Old 04-22-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
I think you found the "right" answer to your problem - sounds exactly like the rev limiter kicking in...
UK-C200 is offline
#5 Old 05-24-2012
Vehicle: '99 SLK 230
Thanks for the update! Just replaced the CPS and was having the above issue... thanks for the answer!!
tee51397 is offline
High RPMs/Very Loud Sound Valley SLK R171 General Discussion 16 06-10-2014 04:38 PM
daytime running lights & high beams bobl SLK R171 General Discussion 16 11-10-2010 11:58 PM
