Steering damper - Mercedes Benz SLK Forum
#1 Old 04-19-2012
Steering damper
Changed my steering damper last week, have to say made an amazing improvement! It 32$ online,took and hour and really was pretty easy!
My car has 110k and was or well maintained, but this was an easy cheap fix!
Klonny is offline
#2 Old 04-19-2012
Yup, it makes a big difference. I did mine about the same mileage two years ago.
#3 Old 04-20-2012
kcflhrc's Avatar
Vehicle: 2001 SLK 320 Magma Red
The one on my wife's 01 320 is leaking oil. I notice a vibration in the wheel on certain types of surfaces. I ordered a new one, haven't put it on yet. Hopefully that is the problem. Just put on new tires and balanced so I don't think that's the problem.
kcflhrc is offline
#4 Old 04-20-2012
The damper should solve that problem.
#5 Old 04-21-2012
galaxys's Avatar
Vehicle: 2011 SLK 300 Plutonium (Sold 2002 SLK 230)
Quoted: 16 Post(s)
Also just received one and just need to find some diy steps to put it in...
galaxys is online now
#6 Old 04-21-2012
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
I have 110,000 on mine as well sound like a good maintenance item to do. Will look forward to some one posting a do it your self page.
raybonj is offline
#7 Old 04-21-2012
kcflhrc's Avatar
Should be pretty easy, just need the torque specs if anyone has them.
kcflhrc is offline
#8 Old 04-22-2012
kcflhrc's Avatar
Tackled this little project this morning. Quite easy, took all of about 20 minutes. Tools required.
1 16mm wrench open and box end
1 16mm socket with ratchet
I jacked up the passenger side of the car with my floor jack to get a little more work room.
The passenger side is just a bolt threaded into another piece of the suspension. No nut on this side. I had to use the wrench here because there is a support bracket in the way to get the socket on.
The driver side was a bolt and nut. You will need the wrench here to hold the nut on top while you use the socket to remove the bolt.
I did not have torque specs but these are big bolts. Very unlikely you will break these unless you use an impact.
Put the new stabilizer on in reverse order and that was it. Will test drive after while and see if there is any difference. The old one seemed worn out compared to the new one.
Keep in mind this was on an 01 SLK 320, your vehicle may be different.
kcflhrc is offline
The Following 2 Users Say Thank You to kcflhrc For This Useful Post:
#9 Old 04-22-2012
kcflhrc's Avatar
UPDATE: test drive went fine. Seems better for sure, maybe a little tighter. Guess time will tell if that vibration is gone. Only happens on certain road surfaces.
kcflhrc is offline
#10 Old 05-25-2012
I have a 2001 SLK 320. So, there are two steering dampers (driver side and passenger side) correct? Does anyone have pics of location?
okiesho is offline
#11 Old 05-25-2012
kcflhrc's Avatar
No, just one.
kcflhrc is offline
#12 Old 05-26-2012
Vehicle: 2000 SLK230
Other Toys: 2007 Cadillac CTS (Manual Tranny)
I have a quick question, I just replaced my steering damper yesterday, and I replaced it the exact same way that the old one was in there. Upon reading the new damper though, and the arrow pointing in the direction of the frame, it makes me think the previous one may have been in backwords. I attached a picture, from the drivers side. If anyone could tell me if it looks right, or upload a picture of theirs just so I could double check and make sure it is in properly, I would be greatly appreciative.
Thanks,
Michael
Maddogmsd is offline
The Following User Says Thank You to Maddogmsd For This Useful Post:
#13 Old 05-26-2012
kcflhrc's Avatar
Mine is installed the same as yours in the photo.
kcflhrc is offline
#14 Old 10-23-2012
PMB
Vehicle: SLK320
Other Toys: 2006 Mini Cooper, 1981 Yamaha RD250LC, 1996 Suzuki Bandit 600, Motobecane AV92 (being restored).
I have been following this thread, and my question is - did it take away the vibration?
It only happens on mine between 60 and 70mph. As soon as you go into even a slight bend at that speed the vibration goes away, only to return when you straighten up.
PMB is offline
#15 Old 10-23-2012
kcflhrc's Avatar
It took the vibration out of my wife's 01 SLK 320. Her's was actually leaking oil out of one end so it was obvious it was bad. I noticed it one day getting on the freeway on the ramp. Steering wheel kinda shook back and forth, not really a vibration, just a slight back and forth until I passed about 65 mph and it went away. Didn't do it all the time. Seems road surface played a part too. Replacing was easy. Took all of 30 minutes maybe. Here's the one I bought at Parts Geek. Good luck
http://www.partsgeek.com/catalog/200...ng_damper.html
kcflhrc is offline
The Following User Says Thank You to kcflhrc For This Useful Post:
#16 Old 10-26-2012
Vehicle: 2003 slk32 amg black
about to change out my steering damper
need advise on if i should go with oem or off brand. i looked into autozone's damper:
http://www.autozone.com/autozone/par...0471_326705_0_
and their's has a lifetime warranty on it. meaning when ever i to change it out, i just take it back and they give me another one.
has anyone put one of these on their slk?
pi_4x4 is offline
#17 Old 10-26-2012
kcflhrc's Avatar
I don't have real high opinions of AutoZone, I think I would go with OEM. I bought a set of so called life time brake pads from them for my 07 Tahoe. Not cheap one's either, brand name. Employee said everything is in the computer, you don't even need your receipt if there is ever an issue just bring them back. The front pads started to squeak. I took them off and they had hair line cracks all over them. Took them back, guess what? You got it, we don't see that you purchased those here. I'll never go back. I use Oreilly's almost always now.
Bradley61496 likes this.
kcflhrc is offline
#18 Old 10-27-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Way too much Chinese junk out there. You can buy the OEM part from some of our trusted online sellers for around $30. That would be Stabilus or maybe Febi.
Len
1999 E300D 215,000 miles
sokoloff is offline
#19 Old 10-27-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
My steering wheel shakes a little going down the road at about 60mph, it had 60,000 on it with new tires, do you think this will fix the problem?
Bradley61496 is offline
#20 Old 10-28-2012
Guys, it's a $30 part (go oem or oem equivalent! ) and 2
Bolts, literally like 20 minutes for me and I barely know which end of a screwdriver to use! Truly no brainer ( just be sure to use jack stands and since I'm freaked out about getting squished I used cement blocks as backup! )
If you are over a 100k swap it out!!
Klonny is offline
The Following 2 Users Say Thank You to Klonny For This Useful Post:
Steering Damper & Serpentine Belt DJC013 Where to get R170 SLK Items 4 04-03-2011 12:40 AM
