Fog lights stay on - Mercedes Benz SLK Forum
  • 1 Post By jbanks15
#1 Old 04-16-2012
Vehicle: 1999 slk 230
Fog lights stay on
After overnight rain my battery died. I jump started it in morning and noticed that fog lights were on even without turning the switch on. I turned the car off and fog lights were still on. What are usual area of short circuit in car?
slimsol is offline
#2 Old 04-16-2012
Quoted: 6580 Post(s)
is the light switch pulled out to engage fogs inadvertently?
AlmaSLK likes this.
#3 Old 04-16-2012
no. I the light switch is in off 12 oclock position.
slimsol is offline
#4 Old 04-16-2012
but is it pulled out or pushed in? that usually controls the fogs
#5 Old 04-16-2012
its pushed in.
slimsol is offline
#6 Old 04-16-2012
dang! there went that idea.
#7 Old 04-16-2012
I think there is short circuit in trunk
slimsol is offline
#8 Old 04-16-2012
leapyfish's Avatar
Check the PSE,
also clean you drains rear drain problem - Benzworld.org - Mercedes-Benz Discussion Forum
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#9 Old 04-16-2012
Originally Posted by leapyfish View Post
my pse pump is already blown. It has never worked since i got my car(I assumed tht cuz door lock and rear defroster isnt working.) Can i just removed PSE fuse?
slimsol is offline
#10 Old 04-23-2012
Does PSE pump control fog lights too? My fog lights and parking lights stay on even after removing key
slimsol is offline
#11 Old 04-23-2012
Firm's Avatar
Definitely wet PSE. Read some of the threads on here for more details. But basically you'll need to pull it out, dry it out, and then put it back in. Make sure you clean out your drains and seal up any leaks to prevent it from getting wet again.
Firm is offline
#12 Old 04-24-2012
I removed PSE pump from car. i will wait till weekend and see if battery dies
slimsol is offline
#13 Old 04-24-2012
While you are at it, you may want to clean all of the drains on your car... have a look here: https://www.slkworld.com/slk-r170-cla...-cleaning.html
Good luck sorting out your problem
Raindog
Raindog is offline
#14 Old 04-24-2012
Vehicle: 2001 SLK 320
Fog lights stay on after you get out of the car dont they?
(at least mine do) and then shut off like a few minutes later, but stay on if I leave the door open. May be a door sensor or something similar too.
Arachnyd is offline
#15 Old 03-18-2016
sladelefty's Avatar
Vehicle: 2001 SLK 230
fog and running lights not going off
I have the same problem. Fog and parking lights do not go off unless battery is disconnected. What did you finally end up doing. My PSE was completely dry. I live in New Mexico.
Thank You.
sladelefty is offline
#16 Old 03-19-2016
i removed fuse for fog lights. it happened only when it rained tho
slimsol is offline
#17 Old 03-20-2016
sladelefty's Avatar
I took the bottem off of the PSE and found that the relay closest to the outside middle was stuck closed. I put some matchbook cardboard between the points and now all works well but no fog lights but who needs fog lights in the high desert.
Thank you for getting back.
Slade
#18 Old 03-20-2016
Slade
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
#19 Old 05-08-2018
2001 slk230 amg front bumper
i change my front gumper from a stock bumper to the amg bumper. The problem is the original fog lihts wont fit the new amg bumper. Does any one know what kind of fog lights go with this bumper. i bought 3 kind of fog light that look like it fits but it dont....thank you
superman is offline
#20 Old 05-08-2018
Welcome
post an intro
update your profile, model n year n location
then we can answer your question when we know what you are driving
this thread is 6 years old
you might want to post your question in the appropriate generation section
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300, 320, 350, 55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: New Members Introduce Yourself Here - Mercedes Benz SLK Forum
how to get fog lights on without main lights... wedge357 SLK R171 General Discussion 23 11-23-2016 04:08 PM
Fog Lights On - Won't turn off studdy05 SLK R170 General Discussion 12 02-26-2012 04:59 AM
lights stay on, key remote not working, code on radio jvbutter SLK R171 General Discussion 0 01-15-2011 11:24 PM
xenon fog lights !! no-way Performance MODS for the R171 16 09-14-2010 11:21 AM
Fog lights C32 - SLK32 csa02221862 General Modifications R170 7 06-23-2010 11:56 AM
