Shaking at red lights - Mercedes Benz SLK Forum
 15Likes
#1 Old 04-13-2012
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
Hey guys, so it's been a while and that's because the car has been running perfectly!
Well, for a couple of months now, every time I pull up to a stop sign or a red light (basically, foot on brake while in drive) the car starts to shake. Not the "I'm running on 3 cyl" or"I'm starving for fuel" shake....I just don't know where to start?
I replaced the plugs and it's the same. Cleaned the MAF too... It accelerates beautifully and it runs perfect in neutral, so I know it's not the fuel filter. I've also found some threads about same symptoms and it turned out to be engine mounts, but again, I don't think that's it either cause once in a while, she doesn't shake at all while stopped! So if this were the mounts, it would be all the time, right? Is it one of the coils? Omg, help!
I just don't know where else to look or change? I hope somebody experienced the same problem and got it fixed?
Las VegasCop is offline
#2 Old 04-13-2012
Quoted: 6580 Post(s)
We missed you! will be in vegas May 4-7th
#3 Old 04-13-2012
Have a look at the mounts and see if they are leaking, they could be at the begining stage of going bad.
#4 Old 04-14-2012
Vehicle: 2003 SLK32 AMG
Other Toys: 73 Mustang convertible
Quoted: 15 Post(s)
Send a message via MSN to adrose Send a message via Skype™ to adrose
I had the same problem....broken engine mount....changed out all !
A
adrose is offline
#5 Old 04-14-2012
MrG
Vehicle: Black '02 SLK320
With or without A/C on??
MrG is offline
#6 Old 04-15-2012
The mounts appear fine....as I stated above, Its been going on for about 2-4 months and within that period, out of no where, the shaking stopped, but only for a day. That only happened only 2-3 times...so I can only guess, if those were the mounts, wouldn't the shaking never stop? I mean, once the mount(s) go, they go, they just cant fix themselves for a minute?
I dumped some injector cleaner couple weeks ago.....twice....still same
The AC is off....In the old days, I would probably go for a vacuum leak, but these days???? Just dont know....mannnnnnnnnn
#7 Old 04-15-2012
Heyyy brother! If you're in town, please shoot me a PM...I get those directly to my phone soooo
Im off that weekend so we must grab a beer
#8 Old 04-15-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Bad mounts you can also sometimes feel in reverse. If yours are original, they are getting kind of long in the tooth.
Len
Len
1999 E300D 215,000 miles
sokoloff is offline
#9 Old 04-15-2012
Location: Bloomfield Hills Michigan, Spring Hill Florida & Lantana Texas
Vehicle: 2006 SLK55
Other Toys: 2015 Dodge Durabgo RT and 2014 Chrysler 300 SRT
When it shakes with your foot on the brake with the A/C off, is the vehicle at operating temperature? What RPM does the shake occur?
I would tend to agree it may not be the fuel filter and/or fuel pump because of the variablity of the shake. I had an 1979 Mustang Pace Car (many years ago) that after it was tracked would shake at lights with variablity as you mentioned. Ended up selling it B4 moving to Mexico and never learned what caused the shake????
matton is offline
#10 Old 04-16-2012
Len
When I put it in neutral it stops...it shakes in drive or reverse....operating temp has nothing to do with it. What I mean by that, it doesnt effect it if I just started it or I've been driving for 3 hrs (just got back from a 280 mile trip) and still the same. Also the embient temp has no obvious effect on it either! What gives?!?!?!?!?!?!?
#11 Old 04-16-2012
It shakes while in gear because its under a load.
#12 Old 04-16-2012
Vehicle: 2006 SLK55
That's why I asked about the RPM..... Hopefully, a simple adjustment of idle RPM but the variability of the shake is puzzling ???
matton is offline
#13 Old 04-16-2012
Vehicle: 2006 SLK280 MT
Still sounds like motor mounts to me. Visible inspection is very difficult unless you have a new one to compare. There might not be any visible leakage, but the mount can still be collapsed. Given it's a 2001, if the mounts have not been replaced I would do it just on age alone.
Iridium is offline
#14 Old 04-16-2012
Correct.....
And ref the RPM....it's same in gear or neutral, around 600-700.....nothing outrageously low or high....
The car is 01 with barely 84,000 miles on....so you still think it might be the mounts??????
This is starting to really piss me off now guys....I need to get this thing sorted out, I'm planing on giving her to my daughter for her sixteen birthday in June so we still have some time to get this thing sorted out....
Should I take her to the dealer for just the diagnostic? I am more then capable of buying my own parts and replacing them....pin pointing the issue without the proper knowledge and tool, that's another thing
#15 Old 04-16-2012
Did you check the transmission mount?
#16 Old 04-16-2012
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Correct.....
Eleven years old is more telling than 84K miles. If original, they are due to be changed. If it goes away in neutral, then it is almost certainly the mounts. Mercedes is offering a complimentary spring check and clean up for owners. If it makes you feel better, call your dealer and go in for the free look over and see what they find. Nothing wrong with mine, but I'm taking it in anyway for the pros to pick it apart and try to sell me services. I do all my own work and use checks like this to point me to things I may have missed.
Len
slk320chick and Tolak like this.
Len
sokoloff is offline
#17 Old 04-16-2012
Gotcha.....
If I don't come up with anything solid in the next couple weeks I'll get it diagnosed at the dealer
#18 Old 04-16-2012
I know what you're saying brother and I would've replaced all of them except it stops shaking once in a blue moon
I would think it would never stop if the mounts were gone
But I will get to the bottom of this ....that's a promise!
#19 Old 04-25-2012
ok...update!!!
It's not fixed buttttttttttttttttt.....I threw an Engine Light today on the way to work!!!
Its a P0440....Evaporative emissions control system malfunction?????
Nevermind...I had my girl go get me some gas since I was running late and she didnt tighten the darn gas cap right!!!! Dang it....that's fixed but the shaking is still there....FYI
BTW....I gave in...ordered the left engine mount today!! What the heck...gotta start somewhere right?!?!?!?!?
#20 Old 04-25-2012
ok...update!!!
Hate to say it but you should replace both sides at the same time.
how to get fog lights on without main lights... wedge357 SLK R171 General Discussion 23 11-23-2016 04:08 PM
lights stay on, key remote not working, code on radio jvbutter SLK R171 General Discussion 0 01-15-2011 11:24 PM
Red warning lights for an open door richard_leeds General Modifications R171 4 11-02-2010 06:04 AM
Finally installed Projector Lights. SLKman SLK R170 General Discussion 6 05-18-2009 01:42 PM
How PC can you get ? Woolly Off Topic 1 02-28-2007 08:05 PM
