Car won't start, battery seems ok - Mercedes Benz SLK Forum
  • 1 Post By jbanks15
#1 Old 04-08-2012
Vehicle: 1998 SLK230
My 98SLK230 would not start after a short drive. Not a click or anything. Had been starting and driving great until then. Had AAA come and jump started fine. Drove home and top would not go up, even with engine running. Would not restart, again not even a click. Put on my trickle charger for five days and no affect. Jump started it again, and with engine running top would not activate, and radio would go off when I was pushing roof switch. With motor off power door locks work but headlights do not come on. Battery was new last fall, and measures 38 volts while running and 35 volts when motor is off. Fuses look ok. I'm at a loss, and hope someone in this forum can help.
Blackshirtbenny is offline
#2 Old 04-08-2012
Quoted: 6547 Post(s)
Thank you,
Moderator/Founding Member
#3 Old 04-08-2012
Most would say, get a new battery and see what happens. try a search top right, if you haven't already. some members will chime in
you said 38 volts and 35? not 18/15?
#4 Old 04-08-2012
Firm's Avatar
Start with the simple things. Check that your cables are connected to the battery good and tight and that there is no corrosion build up on them. Then try a new battery, maybe the battery has shorted out inside or something. A bad battery can do a lot of weird things to these cars.
Firm is offline
#5 Old 04-08-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
What they said - most Auto parts stores stateside will do a free battery test. I'm assuming the 35/38 volts is a miss-type, else you have some major problems..
UK-C200 is offline
#6 Old 04-09-2012
Battery checked out ok
Took the battery to auto parts store. 12.80 volts, 827 CCA, so better than rated 770 CCA. (My cheap little multimeter must be bad.) I wanted to drive over, but could not jump car today ... Only got a click out of it, nothing else.
So, got home and put the battery back in. On a whim, I put in the ignition key and the car started right up! I was also able to put the top back up, and everything seems normal.
So, I'm one confused SLK guy. Don't know if my car is all good or it will die on me sometime in the future.
Any ideas as to what is going on and what I need to do?
#7 Old 04-09-2012
connectivity? bad battery cables now in alignment?
#8 Old 04-09-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
I'd check the terminals and the battery leads for corrosion as a starting point now that the battery has tested good. Normally the leads are "ok" if you can jumpstart the car, but never hurts to check.
UK-C200 is offline
#9 Old 04-09-2012
John! get out of my head!
UK-C200 likes this.
#10 Old 04-09-2012
aka John
Chats: 1143
Quoted: 30 Post(s)
Great minds and all of that!
UK-C200 is offline
#11 Old 04-09-2012
Thanks to all for your suggestions. Cables look good and were tight, no corrosion (a little petroleum jelly does wonders). I guess it will be wait and see, but am still mystfied why jumping it didn't work earlier.
#12 Old 04-09-2012
certain way to jump batteries. forgive me. but one was grounded, right?
Car won't start...help!! runepcc03 SLK R170 General Discussion 12 07-03-2011 08:07 PM
Mbrace alarm activation zich6 General Discussion 41 06-10-2010 10:49 PM
Is it possible to lock the keys inside the car? Eduardo SLK R171 General Discussion 10 12-31-2009 01:10 AM
I give you a dedicated thread to the CLK GTR AMG,built to prove AMG's dominance alroumi AMGs 0 05-04-2008 02:17 AM
