Stainless Steel roll bars. - Mercedes Benz SLK Forum
#1 Old 08-20-2015
Quoted: 12 Post(s)
I ordered a set of Stainless Steel roll bars from Ebay. It took 3 weeks to get here from Germany, but they arrived in good shape. They were fitted right.
Installation was easy except for the flat trim pieces.
I still haven't figured how to get them in right. The directions are in German and tiny print.
If anyone has a way of getting them in. please let me know.
But they look great.
rt1092 is offline
#2 Old 08-20-2015
simplyslk's Avatar
Other Toys: '13 GLK350
Quoted: 235 Post(s)
I don't know how to install them (mine came with the car) but they'll look very nice.
Don't forget to post pics, please.
Marykay
simplyslk is offline
The Following User Says Thank You to simplyslk For This Useful Post:
#3 Old 08-20-2015
They should be a direct bolt on part, what kind of a problem are you having with them? some pictures may also help.
#4 Old 08-20-2015
RoboRob's Avatar
Vehicle: 2002 SLK320 6 speed
Quoted: 17 Post(s)
If the "flat trim pieces" you mean are the bottom steel plate between the roll bar and finish, it should be easy. You use the existing outer trim piece from the existing roll bar set up. Should be self explanatory. New plate should even have matching cogs that fit into existing slots on existing trim.
If the "flat trim pieces" you mean are the rubber seal between new roll bars and new bottom steel plate, thats more difficult, but is do-able. My rubber seals on first inspection appeared to large and had no way of staying in place. How I remedied this was, twist the rubber seal inside out and slowly cut a groove into the centre. I tried first a blade (exacto / very sharpe), but thus just cut a slice into the rubber and gave no "groove for the steel plate to sit in. Also very easy to "over cut" and slice right through the rubber. A hack saw blade was next try. It worked perfectly. Wouldn't cut right through by accident and was the perfect width, removing just enough rubber to form a groove for the plate to sit in. Just hold the rubber between thumb and finger and slowly "saw" a grove, rotating as you go.
Fitting the rubber seals onto the plate was tricky, patience is needed for it to stay in place. Now, sliding the roll bars in was hard but again, patience is needed. Several tries will be needed but, again, do-able. I rubbed a little wet hand soap on the roll bars to give a slippery surface that would dry up once finished.
Took me maybe an hour for all this. Removing all the pieces on the car to get to the roll bar attachment points took just as long. Be very careful removing the screw that are set into the body work. If they fall, they are gone.
Hope this helps. Search this board, I think there are instructions on how to install these, just cant remember where.
RoboRob is offline
The Following User Says Thank You to RoboRob For This Useful Post:
#5 Old 08-21-2015
Quoted: 12 Post(s)
I found this to help with the installation.
http://4x4icon.com/crossfire/roll_ba...%20install.pdf
It's the flat steel trim pieces. I was able to pop them into the molding, But only with the molding off the liner (piece that goes across behind the headrests).
I'll be out of town till Aug 31 I'll take some pictures and work on it when I get home.
Thanks.
rt1092 is offline
The Following User Says Thank You to rt1092 For This Useful Post:
FS SLK R171 OEM Windbraker and Roll Bars cbre31 SLK Parts For Sale 5 04-10-2012 08:20 PM
dumb question - roll bars bobl SLK R171 General Discussion 5 06-16-2011 12:16 PM
Help with replacing roll bars!! MDS General Modifications R171 8 02-03-2009 06:49 PM
Satined roll bars Banned Performance MODS for the R171 11 04-26-2007 12:24 PM
