Under bonnet EXTREMELY hot but temp reads fine on dash - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By Jet Wrench
  • 1 Post By ichris93
#1 Old 08-15-2015
2_Big_Red_Dogs's Avatar
Vehicle: 2000 SLK 230 (R170)
Quoted: 12 Post(s)
The other day I was standing outside talking to a friend while my car was running. I leaned up against my car and about burned my booty off! I took a look at the temp guage inside my car and it was very slight (maybe a needles width) above the exact center line. I popped my hood and EVERYTHING under the bonnet was too hot to touch. You could feel the heat coming out from a couple feet away. I checked my coolant level and it was right at the "minimum" mark in the overflow tank (I didn't see any "maximum" line marking. I drove home and popped the hood. Waited a good 30 minutes and everything was still quite warm and the engine itself was still so hot that I could only touch it for a second or two. I touched the hoses connected to the radiator and found something interesting. The top part of my lower radiator hose was still pretty toasty, but just below the little clamp that holds the hose in place about midway down it, it wasn't even hardly warm. The farther down I followed that hose, the cooler it got. Could my engine be overheating but the temp on the dash guage read OK? Maybe a stuck thermostat?
2_Big_Red_Dogs is offline
#2 Old 08-15-2015
Vehicle: 1999 slk 230
Quoted: 518 Post(s)
Depends how long the car idled it takes a little while before the thermostat will open if you still have the problem after about 15 min. than i would say yes replace it.
Berliner Heckflosse is online now
#3 Old 08-15-2015
Vehicle: 170 230k
Other Toys: 170 230k project
Quoted: 45 Post(s)
hey red dogs,i have a C55 AMG and the under bonnet temp is just the same.its a big mill motor and its fine
gordonian is offline
#4 Old 08-15-2015
Quoted: 12 Post(s)
Thanks for the replies and the reassurance! It had idled for about 20 minutes. I never heard the fan come on either. But I guess the coolant temp needs to get pretty hot for that to happen? I was at about 85-90 degrees Celsius. It was just alarming because it felt SO hot to my rear LOL. And then feeling how hot everything else was under there too seemed a bit unusual. Man, all those parts, electrical wires, etc. have to be able to withstand a lot more heat than I realized. Is there a "max" line for the coolant overflow? I've been thinking of doing a coolant flush eventually.
#5 Old 08-15-2015
ichris93's Avatar
Quoted: 89 Post(s)
Do you have insulation on the bottom of your hood? A hood pad. That should keep the hood cooler. 85-90C is hot, almost 200 F.
ichris93 is offline
#6 Old 08-15-2015
Quoted: 12 Post(s)
Yes, I do have one. .
#7 Old 08-16-2015
Jet Wrench's Avatar
Vehicle: 1999 European spec 200, 5 speed. Silver exterior, red and black interior
Other Toys: BMW 320d Wagon, Glastron Carlson CVX18, 2013 Harley Davidson Road King
Quoted: 14 Post(s)
The engine bay temps do run high on these cars. If your engine temp gauge is consistent, whether stopped at idle or with forward motion, you should be OK. You will notice a small rise in temp at idle, but that is not out of the ordinary. Just keep checking your vitals before you go and you should be good to go. If you have not replaced your coolant for some time, it may be a good idea to put in on your "to do" list.
El_Toro_33809 and ichris93 like this.
Jet Wrench is offline
#8 Old 08-16-2015
Quoted: 12 Post(s)
Thanks Jet! I'm not sure it's ever been changed. I've had it for almost a year and from the looks of the car when I got it, it's previous parent didn't spoil it. Temp is consistent, witjin the normal range on my guage, and like yiuvsaid, thete is a very slight rise in temp at idle but goes back down when going firwards. I'll be sure to add the coolant flush/replacement to my ever growing to-do list. I'll report back if that makes any difference once it's complete.
#9 Old 08-16-2015
ichris93's Avatar
Quoted: 89 Post(s)
What color is the coolant?
ichris93 is offline
#10 Old 08-17-2015
Quoted: 12 Post(s)
I'm shining a light into the overflow in one of the pictures, so I think that dramatizes the color a bit, but you get the idea.
EDIT: Actual picture as posted doesn't look as dramatic as it looked on my phone. This picture is probably close to actual representation of the color.
#11 Old 08-19-2015
ichris93's Avatar
Quoted: 89 Post(s)
Cannot tell that much. When you change it, use Zerex G-05, it is clear.
2_Big_Red_Dogs likes this.
ichris93 is offline
Bluetooth Puck / AMG Bonnet Grills / Dash Cup Holder / Shorty Aerial Swagman SLK Parts For Sale 12 01-15-2013 01:37 PM
