smells like burning oil? - Mercedes Benz SLK Forum
  • 1 Post By t140v
#1 Old 08-08-2015
Quoted: 20 Post(s)
Hello All,
I was driving around with the top down the other day and what I thought I smelled burning oil. I looked around and did catch some wisps of smoke, like a drip on a hot exhaust or engine block. Couldn't see anything from the top with hood open. I jacked up the car and looked underneath. I took pics of what I saw. searched the net to find out what this black nipple cover is? Any help would be appreciated. Thanks.
Joeb77 is offline
#2 Old 08-09-2015
Quoted: 20 Post(s)
Could it be a manual transmission leak?
Joeb77 is offline
#3 Old 08-11-2015
Vehicle: 2000 SLK 320
Quoted: 54 Post(s)
I have the same model and it has an auto box, but the leaky nipple pictured looks like its on the clutch slave cylinder which you would find on a manual transmition and is used to bleed air out of the system following a clutch or seal change .
I'll have to have crawl underneath to see if mine is the same.
Joeb77 likes this.
t140v is offline
#4 Old 08-12-2015
Quoted: 54 Post(s)
Is it a manual box Joeb?
t140v is offline
#5 Old 08-12-2015
Quoted: 54 Post(s)
If it is then I would check your fliud levels in the clutch fluid reservoir or sometimes the clutch uses the brake master cylinder reservoir as a supply if the levels are down then that's what is leaking from the nipple
The nipple may just want tightening a touch.
t140v is offline
#6 Old 08-13-2015
Quoted: 20 Post(s)
Thanks for the help. It is a manual box. I took the rubber nipple off and it was clean as a whistle. I am thinking the leak may be near by running to a low point which is the rubber nipple. What is the metal silver part where oil is dripping from in the 4th picture (last one)? Also a side note question..... is there an oil drain plug underneath the car? Trying to locate that as well.
Joeb77 is offline
#7 Old 08-13-2015
Quoted: 54 Post(s)
Looks like it is the head of a Torx bolt, dont know any more about the underside of the car, have spent most of my time in the fuse and relay boxes.
Stuart
t140v is offline
DIY Oil Change Coolant/Antifreeze Flush Power Steering Fluid Change Swoley2k SLK R171 Class DIY 5 04-17-2017 05:27 PM
