shaky feeling during idle - Mercedes Benz SLK Forum
  • 1 Post By jbanks15
  • 1 Post By grown_sexy
#1 Old 08-01-2015
Vehicle: 2003 SLK 320
Hello,
I have a slk320 with about 144K on the dash. I noticed lately it's shakes a little when sitting still in lets say park or at a traffic light. its a slight shimmy. its not constant. it will shimmy...stop..wait a little ..shimmy..ect. my guess is plugs and wires. I tried to do it myself. way too difficult. I couldn't even get one boot off. I was able to get it off the plug itself but I couldn't take the other end off. in a nutshell I replaced 1 plug in two hours . my 230 was so easy.
any ideas as to what it could be? also, the plug was a ngk so I think they've been replaced at some point. it did have a Mercedes benz sign on the plug.
grown_sexy is offline
#2 Old 08-01-2015
Quoted: 6490 Post(s)
shaking would be motor mounts, either engine or transmount.
Pelican Technical Article - Mercedes SLK 230 - Engine Mount Replacement
Pelican Technical Article - Mercedes SLK 230 - Rear Engine Transmission Mount Replacement
leapyfish likes this.
#3 Old 08-01-2015
Quoted: 1135 Post(s)
Ngk spark plugs were fitted by mercedes and they just stuck there logo on the ceramic piece
First you have to suss out if the engine is missfiring causing the engine to shake due to it .
And if not then as mr banks said engine mounts worn .
State of the plugs will give you and indication of a missfire .
Delucas is online now
#4 Old 08-01-2015
Vehicle: 2000 slk230
Other Toys: toyota paseo,toyota 4x4,75 triumph spitfire
Usually motor and tranny mounts going bad give you a thunk going into gear or leaving from stop, at 144k I go for major tune up, plugs, coil packs, air filter and check for any leaky air hoses, at least its a start and it has to be done anyway. 320 double the trouble, not double the fun of 230. My daughter has 320 AMG and its a money pit.
swoop is offline
#5 Old 08-02-2015
I had the motor mounts and Trans mount changed out less than 5 months ago.
#6 Old 08-02-2015
Good to know!
Don't hold any info back from the doctors please
#7 Old 08-02-2015
El_Toro_33809's Avatar
Quoted: 86 Post(s)
If the plugs haven't been replaced, they definitely should at 144k. This tool makes pulling the boot easier.
New Karlyn STI Spark Plug Connector Tool 17 mm 22 8613 009 | eBay
The rear plug on the passenger side is challenging as I remember.
Good luck.
Tim
El_Toro_33809 is offline
#8 Old 08-03-2015
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 82 Post(s)
I'm following this with some interest as my 320 does this - 140km, what's that.... around 90,000miles. The plugs were replaced just before I bought it, 2 years/20,000km ago. Anyway, I struggle to understand why a misfire causes a 'shimmy' every second or two. Won't it misfire every revolution?
I don't have a 'thunk going into gear or leaving from stop'. I cleaned the MAF and the cleaner came out just as clean as it went in. It's not a huge issue for me and I don't want to start replacing parts chasing the problem but it would be nice to make it smoother.
I'm not even sure there's anything wrong with it as I don't know anyone else with a car to compare it with. It's just not as smooth as I imagine a 6 cylinder Mercedes should be. And no codes.
Australian is offline
#9 Old 08-03-2015
Omg...the tool I used was pathetic. I'll post a pic later.it literally broke in my hand.i failed miserably. I couldn't take the wires off the packs.i didn't want to risk ripping then in half.how do you remove them? Do you roll the rubber boot up and turn the spark plug wire? I thought you just pull it straight off. I'd love to do the tune up myself.
#10 Old 08-03-2015
https://www.slkworld.com/slk-r170-cla...placement.html
https://www.slkworld.com/slk-r170-cla...park-plug.html
#11 Old 08-03-2015
that's the thread I went by. didn't mention how to yank the plugs off the other end. it only mentioned off the plug itself. I just ordered 6 coil packs for the heck of it. so , now I have plugs, wires and coils. the STI tool is about 28 bucks. one end is open the other is closed. whats the closed end for? the open end appears to be the end you use to pry off the wire from the spark plug.
#12 Old 08-07-2015
Coils came today..looks like wires slip on and off.not sure why I couldn't slide the old wires off of it
Rough Idle (Model 171.473) jameslk55 AMGs 13 11-10-2013 03:33 PM
Low Power, rough idle...One problem after another. fly1705 SLK R170 General Discussion 12 08-21-2013 10:39 PM
320 low idle speed Robert320 SLK R170 General Discussion 0 07-21-2013 09:32 PM
low idle / intermittent rough idle at start up? gertie SLK R172 General Discussion 10 11-13-2012 06:03 PM
Intermittent rough idle w/AC on ablum1 SLK R170 General Discussion 4 06-25-2012 08:01 PM
