Trunk lid doesn't lock in front - Mercedes Benz SLK Forum
  • 1 Post By efair
  • 1 Post By efair
#1 Old 07-31-2015
Quoted: 12 Post(s)
Hi. I can lift the front of the trunk lid up. Even though the back is closed. I've had troubles with my top (haven't got it working yet) I went over a bump and the beeper goes off and the red top switch blinks.
I figure it's the switches for the trunk showing it's open. How do I get the locks to work?
rt1092 is offline
#2 Old 07-31-2015
Quoted: 903 Post(s)
The two boot lid latches must not be engaging when the lid comes down. They probably need a light application of grease. What happens when you try to close with the switch? Light blinks? If so, try unlatching the roof latches manually through the hole in the headliner, then try closing again.
ichris93 likes this.
efair is online now
#3 Old 08-03-2015
Quoted: 12 Post(s)
I loosened the mounts for the locking/unlocking/microswitch. And moved them around I got them to lock. So that when I pull the cables they release. I think I'll rebuild the cylinders before I try to see if that was the only problem. The 2 rear cylinders seem easy to get at the ones under the package shelf could pose a problem.
rt1092 is offline
#4 Old 08-03-2015
Quoted: 903 Post(s)
If they're leaking, definitely fix the leaks first (unless you just like spewing expensive hydraulic fluid everywhere, and have a good supply).
The hardest part rebuilding those two cylinders is removing the yoke at the end of the rod. It takes a lot of holding power to hold the rod while you break it loose. Plus, the hydraulic lines have almost no slack.
efair is online now
Finally fixed my roof/trunk rattle! jbanks15 SLK R171 General Discussion 114 05-25-2018 11:26 PM
Trunk Rattle Solution! B55 SLK R171 General Discussion 100 02-19-2017 07:54 AM
R171 SLK280 Trunk Not Closed Problem - Trunk Is Closed andrew c230k SLK R171 General Discussion 19 01-08-2015 09:52 PM
Is My Trunk Supposed To Open Automatically? amaycg SLK R172 General Discussion 14 07-24-2013 06:54 AM
Water in Trunk Lid F111F SLK R171 General Discussion 10 03-09-2013 11:14 AM
