Two Question on the SLK320 - Mercedes Benz SLK Forum
#1 Old 07-31-2015
Vehicle: 2001 SLK 3.2 V-6
Other Toys: 2012 Infiniti EX35
Quoted: 11 Post(s)
Send a message via Skype™ to Simprof
I'm trying to find out from another member of our forum two things (this time)
1) With the fuel system in CL car in drive at idle what exactly is the engines RPM
2) What is the normal cooling temp when idle the engine in +90 F weather
Simprof is offline
#2 Old 07-31-2015
ichris93's Avatar
Quoted: 89 Post(s)
1) Sorry, but what is CL?
2) With my SLK 230 it normally hovers right around 80 degrees C. In Houston traffic when it was 108 degrees F out it was just at the top of the 80 digits but still below 100. If you are about 100 you have a problem. Make sure to flush your system as maintenance and refill with correct coolant.
ichris93 is offline
#3 Old 08-01-2015
My 320 idles at 500 RPM in drive after warm up. Coolant temp runs between 80 and 90C in 90F weather at idle.
CarolinaBluetec is offline
#4 Old 08-01-2015
john hannon's Avatar
Vehicle: SLK320 Auto 2003
On starting from cold mine ticks over at about 1250 rpm for the first minute, it then settles to c.750 rpm.
Temp gauge sits at 80C most of the time, in traffic it rises to 90C and then when the fan cuts in it drops back down to 80C within a minute.
john hannon is offline
#5 Old 08-01-2015
Quoted: 11 Post(s)
Thanks all for the info. Sound about the same for mine. My other two cars idle after warm-up at 650 to 700 the MB is only 500 to 550 it seemed a little low that's why I asked. As for CL it stands for Close Loop. It means the engine has warmed and the exhaust has reached a temp that the O2 sensors can start to read and send info to the ECU befor that it's called open loop.
Thanks again
Simprof is offline
#6 Old 08-01-2015
ichris93's Avatar
Quoted: 89 Post(s)
Thanks again
That is what I thought you might have meant with CL but just checking. Thanks.
ichris93 is offline
Satellite radio antenna question - SLK320 Rob7412 SLK R170 General Discussion 9 09-25-2012 02:05 PM
SLK320 trailer hitch install question Happycoop SLK R170 General Discussion 1 05-13-2012 04:37 PM
Question about HID RetroFits CedarZ4 General Discussion 1 03-27-2012 06:59 PM
The next dumb question xpcdoojk SLK R171 General Discussion 1 08-14-2008 06:03 PM
