Gear shift - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By leapyfish
  • 2 Post By jbanks15
  • 1 Post By jbanks15
  • 1 Post By ichris93
#1 Old 07-30-2015
Vehicle: 1996 r170 slk230 kompressor
Other Toys: S type Jaguar 2000
Gear shift
Hello again, the car has been on a couple of outings to sort out a few things. One of the most annoying is a vibrating rattle in the gear shift lever when in Drive, move it into 4 and the rattle disappears. I cannot drive around in 4 all the time so I will have to fix it. Any help will be welcome , also how do you adjust the height on the seats? I notice there is a strut of some sort under the seat but I cannot find a lever to operate it.
Oldmangordon is offline
#2 Old 07-30-2015
Seat height adjuster
Sorry what I meant to ask about the seat is, when you operate the height lever and you are in the seat is it supposed to rise? Or do you operate the lever before sitting and then when seated do you operate the lever to get the desired height?
#3 Old 07-30-2015
El_Toro_33809's Avatar
Quoted: 86 Post(s)
To raise it, you should be out of the seat. You can be seated to lower it completely. If you are going in between, once again, you would be out of the seat.
Tim
El_Toro_33809 is offline
#4 Old 07-30-2015
Quoted: 86 Post(s)
Does tha shifter have a loose feel to it? Does it feel like it normally has tension pushing it towards the left? The mechanism can be removed without too much difficulty to be inspected.
The lever to adjust the seat height is on the side of the seat by the door sill.
Tim
#5 Old 07-30-2015
leapyfish's Avatar
The annoying rattle is a worn out rubber washer, its fairly easy repair Reverse switch fix, No backup lights - Mercedes-Benz Forum
The worn out part is the greenish washer in the following pic.
I hope someone can post a part number for the washer.
El_Toro_33809 likes this.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#6 Old 07-30-2015
Quoted: 6489 Post(s)
see the washer? 54?
#7 Old 07-30-2015
ichris93's Avatar
Quoted: 89 Post(s)
see the washer? 54?
I think they would call it a bushing, not a washer.
ichris93 is offline
#8 Old 07-30-2015
epc calls it a washer
#9 Old 07-30-2015
ichris93's Avatar
Quoted: 89 Post(s)
If it is the correct part :P
ichris93 is offline
#10 Old 07-30-2015
We will have to wait for Leapy to tell us
I thought you college edumacated chaps knew everyting
#11 Old 07-30-2015
ichris93's Avatar
Quoted: 89 Post(s)
I do. That is why I will be right
I believe it is 27 gear selector bushing.
ichris93 is offline
#12 Old 07-30-2015
you're right. i did not see that. now i can edit my post and look like i am correct!
El_Toro_33809 and ichris93 like this.
#13 Old 07-30-2015
ichris93's Avatar
Quoted: 89 Post(s)
Go for it, as long as you know I was right.
ichris93 is offline
#14 Old 07-30-2015
In my heart, I know you were right
ichris93 likes this.
#15 Old 07-30-2015
leapyfish's Avatar
Yes,
part 27 it is a bushing, my bad for calling it a washer.
Vario roof
R170 & R171
SLK 230 320 32AMG
#16 Old 07-31-2015
ichris93's Avatar
Quoted: 89 Post(s)
Yes,
To be clear, my hard time giving was directed towards Jeff. Hope there is no hard feelings.
ichris93 is offline
#17 Old 07-31-2015
But he called it a washer so I looked for washers! wahhhhh!
dbgrn and ichris93 like this.
Gear Shift Assembly Replacement (COMPLETED) longship SLK R170 class DIY 13 12-19-2018 08:59 AM
Would Not Shift To 4th Gear SLK300MAINENIAC SLK R171 General Discussion 4 04-13-2015 08:38 PM
Wont Shift out of First Gear DougP SLK R170 General Discussion 1 08-03-2014 05:15 PM
Rectangular plastic base of gear shift leather cover etyu SLK Parts Wanted 4 02-26-2014 01:30 PM
Transmission wont shift out of first gear slimsol SLK R170 General Discussion 2 11-18-2011 10:38 AM
