Question about the 'radio code' - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By Delucas
  • 1 Post By Delucas
#1 Old 07-24-2015
Vehicle: My wife's first 'fun car' 2002 SLK 32 AMG
Other Toys: 2007 Dodge Magnum Police Interceptor
Quoted: 16 Post(s)
Is the radio code needed to allow the radio to work, embedded in the RADIO or is it in the cars ECU?
The reason I ask is we are going to replace the radio in the wife's car with another MB radio that plays CD's which her current one does not.
We have the current radio code. But will the 'new to us' MB radio COME with a new code, or will our current code be what will be needed to make it work?
thx
A rattlesnake in the living room tends to end all discussion of animal rights. "Vengence is mine" sayth the Lord, but sometimes he subcontracts...
wallew is offline
#2 Old 07-24-2015
Quoted: 1136 Post(s)
[QUOTE=wallew;2222674]Is the radio code needed to allow the radio to work, embedded in the RADIO or is it in the cars ECU?
thx[/QUOT
The code is in the radio itself .
You need the 4 digit code that comes with the new radio you are fitting .
El_Toro_33809 and Daveb like this.
Delucas is offline
#3 Old 07-24-2015
Quoted: 16 Post(s)
Delucas,
Thx. That clears that up. In my wife's current radio, the code is five digits not four. Go figure.
So, regardless of which radio we purchase, as long as it COMES with the radio code, we should be plug and play, which I like about these radios.
again, thx
wallew is offline
#4 Old 07-24-2015
Yes think its 5 on the old style radio / cd merc ones .
Yes you need the code or its a brick so to speak .
Its common for the cd side of it to play up on them .
Delucas is offline
#5 Old 07-24-2015
Quoted: 16 Post(s)
The problem we are currently having is the cassette works, but no radio. I'm hoping it's the antenna amplifier, which I have purchased online.
If that doesn't help, then I'm kind of at a loss, other than just replacing it, which we were going to do anyway. She wants a CD player in the car, not the trunk so the easy solution is to just replace the radio. They pull out and go back in like a breeze with the correct tools.
wallew is offline
#6 Old 07-29-2015
Quoted: 16 Post(s)
just thought I would update what I said.
I replaced the antenna amplifier and the radio, which comes on, still does not have any sound coming out of it.
It comes on, it even LOOKS like it is working, just no sound coming out - so it is time for a new radio, which we were going to do any way.
the funny thing is that the cassette works great, just not the radio, which the wife likes to listen to on the way to and from work.
at least I hope that solves the problem
wallew is offline
#7 Old 07-29-2015
There are two fuse's on the back of the factory radio, not sure what their purpose is but it may be the cause of you sound issue.
#8 Old 07-30-2015
Quoted: 16 Post(s)
Actually on the radio in my wifes 2002 SLK32 AMG, the radio only has one fuse. It's a 10amp job and I already replaced it. I also replacxed the three 15 amp fuses in the fuse box, though they tested good when I hooked them to my Ohm meter this morning. There is a 5 amp fuse that I don't have any spares for, so I did not replace that one yet.
Once I purchase a box of 5 amp fuses I will replace that one as well. Though I'd bet dollars to donuts that it will test OK as well - I did pull it and it looks good, but you never know.
wallew is offline
#9 Old 07-30-2015
My own opinion
Is just replace the unit with a new one .
They are so cheap head units and do so much more bluetooth for phone calls ,cd ,rds,dab i could go on .
I changed my original for a Alpine unit and the sound quality jumped quite a bit .
ichris93 likes this.
Delucas is offline
#10 Old 07-31-2015
Quoted: 16 Post(s)
Delucas,
That's the plan.
I asked the wife if she wanted bluetooth and while that would allow her to connect her phone (with the mike addition?) she just didn't get that excited about it.
We will see.
I'll post pix when we get the new radio installed.
wallew is offline
#11 Old 07-31-2015
Originally Posted by wallew View Post
Delucas,
That's the plan.
We will see.
With bluetooth tell her she can stream her fav music from her phone .
If that dont work tell her it can prepare meals to .
Delucas is offline
#12 Old 07-31-2015
ichris93's Avatar
Quoted: 89 Post(s)
Check here if you go bluetooth and want to use the existing mic.
https://www.slkworld.com/slk-r170-cla...icrophone.html
ichris93 is offline
#13 Old 10-01-2015
Quoted: 16 Post(s)
Well, it only took two months, but I FINALLY got a replacement radio for my wife. Got it off of Ebay and it was exactly like the one she had.
So I disconnected the battery, removed the old unit, disconnected the four plugs. Put the four plugs in the new (to me) unit, reconnected the battery and tested it.
INSTANT SOUND. Boy that was easy. So I slid the new (to me) unit in place and had the wife reprogram all her radio stations. It took her about five minutes to do that.
So my wife is a happy camper. I talked to her at work today and she said it worked great.
The replacement radio, a factory replacement with the code included cost me $50. It took me less than five minutes to replace the old one and put in the 'new' to me radio in my wife's car. ALL DONE.
Next up is replacing all the shocks with Mercedes Benz shocks.
Anyway, one less thing to fix.
And eventually, I will replace the 'older' unit with a bluetooth one, once I get all the other things fixed and the car paid off. So hopefully, by this time next year, all will be as it should.
wallew is offline
#14 Old 10-02-2015
Vehicle: 2003 SLK32 AMG
Other Toys: 73 Mustang convertible
Quoted: 15 Post(s)
Send a message via MSN to adrose Send a message via Skype™ to adrose
Thats a great trade...can we see a picture of your wife?
adrose is offline
#15 Old 10-02-2015
Quoted: 6496 Post(s)
Here's my wife
gaymerz
Radio Code Sequence 2003 SLK320 JamesMarshal SLK R170 General Discussion 12 01-28-2017 02:37 PM
The radio died, only the cassette still works wallew SLK R170 General Discussion 2 07-01-2015 02:51 PM
Option Code 531 with 535 - Comand and Audio 20 radio Racer944 SLK R171 General Discussion 6 03-14-2012 04:24 PM
Stock Radio Question HogKiller SLK R170 General Discussion 4 10-03-2010 01:11 AM
