Slk 230 no start... - Mercedes Benz SLK Forum
  • 1 Post By Livefreeordie
  • 1 Post By efair
#1 Old 07-23-2015
Organoid's Avatar
Vehicle: 2003 SLK230
Slk 230 no start...
Ok i have seen a lot of posts here and followed them all but it does not fix my issue. I have a 98 slk230 sport... I turn the engine and the lights turn on, but the starter dosnt engage... I was told it was one of five things...
One: battery, battery tested good and no bad cells
Two: battery power relay, replaced with brand new
Three: starter, replaced starter with new one... During the test to see if this was the final step the starter made two rotations to try and engage the engine but then stopped... Ever since then we are back at step one...
Four: the k40 board... No burnt fuses and board looks brand new
Five: crank position sensor, replaced and same issues.....
I am now at a loss as to what the problem could be... All electronics work, but no engine.. I could use some assistance with this
Organoid is offline
#2 Old 07-23-2015
Try putting some cables on the battery to jump it, if it starts its the battery. One problem I had years ago was the K40, all looked good but investigating further with a magnifying glass I found several solder joints cracked.
El_Toro_33809 likes this.
#3 Old 07-23-2015
Quoted: 901 Post(s)
I'm guessing rotten battery cables. Emphasis on guess. A voltage drop measurement across the main cable would be helpful.
ichris93 likes this.
efair is offline
#4 Old 07-24-2015
Other Toys: '13 LR2, '11 z71 Suburban, '09 Yamaha R6S
I am not sure if yours is exactly the same as my 2002, but there is a control module for the starter in the engine bay fuse box. If you remove the cover surrounding the fuses, you will see it. The light purple wire with a white stripe is what you want to look for. Have someone stick it with a test light when you turn the key to start the car. If your test light illuminates, then you know it is trying to run the starter. This should at the very least help you isolate the issue. I would also check each and every fuse...doesn't hurt when you are stumped.
TehRage is offline
#5 Old 07-28-2015
Vehicle: 2000 slk230
Other Toys: toyota paseo,toyota 4x4,75 triumph spitfire
Just curious, does your radiator fan come on when when you turn key and get no reaction from starter?
swoop is offline
#6 Old 07-31-2015
Hi Swoop
Yes I've had that problem you described. My slk170 2003 will randomly not start although all warning lights come on and all electrics work fine. However the fan will come on. Any ideas?
Tsquiz is offline
#7 Old 07-31-2015
Quoted: 6489 Post(s)
Tsquiz,
Swoop did not have the issue, Organoid the poster did
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
#8 Old 07-31-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
The OP has not come back in a week, so assume ok, or s/he has lost the will to continue living…
As asked above, have you voltage going to the starter motor?
I cannot remember when the K40 was modified, but if you have an old one, I understand that they might look ok, but there were sometimes dry solder joints in there.
Are you sure the CPS was replaced with new?
There is another item that can fail that you do not have in your list - the ignition/start switch.
Have all codes been cleared?
Hal Adams is offline
SLK 230 won't crank?! No start error messages Jay Cartay SLK R170 General Discussion 31 04-18-2017 08:25 PM
Slk 230 1998 auto won't start ingm80 SLK R170 General Discussion 3 03-06-2015 12:29 PM
Updrading From SLK 230 R170 to SLK R171 austaccomm Australia 7 12-30-2012 09:44 PM
slk 230 START ERROR :( porsche 944 SLK R170 General Discussion 3 11-05-2012 09:07 PM
