aerial amp power problems - Mercedes Benz SLK Forum
#1 Old 07-08-2015
Vehicle: 2002 slk 230
Quoted: 21 Post(s)
I have looked for yonks on here but cant find a definitive answer, I have replaced my radio (couldn't tune in to any stations) with a MF2199 player, this radio doesnt pick any stations either.CD player works. I have checked the aerial amp and there is no power getting to it, I have checked the blue/white lead on rear of radio and there is power there when you turn it on/off, so conclusion fuse blown, question is where is it?its not listed in the front or side fuse boards, and there is a small fuse box in the rear, but only 3 fuses here for the hydraulic pumps etc.
Has anyone any idea? its a 1998 SLK230
allenhh is offline
#2 Old 07-09-2015
Quoted: 21 Post(s)
update
Well I have spent a happy hour or so on the workshop manual, not an easy thing to use, however it appears the power goes directly to the amp from the radio (no fuse or relay) via a connector Z28/18 which as far as I can gather is pin 5 on the radio. So i either have a break in the wire or a very poor earth on the amp.
Sigh
allenhh is offline
#3 Old 08-23-2015
Quoted: 21 Post(s)
fixed,
having put 12v from the acc switch to the amp and quite a nice mellow POP and odor of fried electrics when i switched on,I replaced said amp. still no radio, further investigation reveled that there is only 1 thread in the core of the coax antenna cable, and mine had snapped in the plug which fits in the rear of the head unit.New plug and re trimmed cable later, I now have a working radio.....deep joy.
allenhh is offline
The Following User Says Thank You to allenhh For This Useful Post:
#4 Old 08-23-2015
cnovack's Avatar
Vehicle: 2014 SLK55 AMG
Other Toys: 2012 ML350, a fresh water boat and a powered parachute some years ago...
Quoted: 66 Post(s)
Thanks. Being an ex-electronics tech I enjoy a good troubleshooting story.
The Black Adder
  • Obsidian Black Metallic with Bengal Red Premium Leather interior
  • AMG Handling pkg
  • Magic Sky Control
  • Multimedia pkg
  • Lighting pkg
  • Keyless-go
  • AMG Illuminated Door Sills
  • Digital Dual-Zone Climate Control
  • Black Ash Wood Trim
  • AMG 18" Multi-Spoke Alloy Wheels in Black Matte
Pimpin' my ride
  • AMG AFFALTERBACH Chrome Steering Wheel Badge
  • WINDRESTRICTOR Option 12
  • 1 ea - 7 inch Hula-Hula girl
  • South of the Border car magnet
  • Bigfoot car magnet (coming soon!)
cnovack is offline
#5 Old 08-23-2015
Quoted: 901 Post(s)
Any idea why it let the smoke out? Is it not safe to connect+12V to the amp?
I'm in the middle of replacing my HU....
efair is offline
#6 Old 08-24-2015
Quoted: 21 Post(s)
You do get 12v from the blue and white wire from the head unit, but for no apparent reason I can see, mine started at 12v (read from the amp) then went to zero...so i thought i had a dickey supply, hence using the 12v from the acc cable, which turns out to be wrong and thats why my amp blew up...
So to sum up use the blue and white wire from the head unit to power the amp and if you don't receive any radio signal, look at the aerial connector on the rear of the head unit to check your wire strand hasn't broken, it is very difficult to see.
allenhh is offline
#7 Old 08-24-2015
Quoted: 901 Post(s)
I put a different head unit in and it started working, so I assumed that my old head unit was bad... I'll check this before installing the new head unit. So the 90-degree connector is where it frayed?
efair is offline
#8 Old 08-25-2015
Quoted: 21 Post(s)
No it didn't fray, it only has a single wire in the central core and it had snapped, but you could only just see it.where it joins the central pin.
allenhh is offline
My Install of Aftermarket HU and Amp to Replace Comand / HK (1 of 2) Fisch27 General Modifications R171 44 02-27-2018 04:04 AM
Can I borrow an aerial? - in Gloucester, UK ;-) Nosnibor SLK R171 General Discussion 19 01-29-2015 07:54 AM
U.S. auto industry quality slips for first time in 16 years: survey jbanks15 Off Topic 0 02-12-2014 11:32 AM
NTG2.5 aftermarket amp install Adamkun SLK R171 General Discussion 1 10-01-2013 09:48 AM
Replaced the OEM Amp sseag612 SLK R170 General Discussion 1 03-25-2012 09:36 PM
