transmission harness adapter - Mercedes Benz SLK Forum
#1 Old 07-07-2015
Vehicle: 1999 slk 230
Other Toys: zx11 ninja, zx10 ninja zrx1100, sv83 Suzuki
Quoted: 27 Post(s)
Hi every 0ne, today I received the transmission harness adapter with new O rings to replace the old adapter, I was able to rotate the retaining ring from 11 0'cklock position to 7 O'clock position and removed the harness, then by unscrewing the middle screw I pulled the housing out, put the new one in and I plugged the harness, I was not able to lock the ring meaning to bring the wing tab to 11 o'cklock position, I took the car for a ride did not feel right it was stuck on first gear.
brought it back removed out the adapter and the o rings tried to redo did not work.
the question is, for who ever has done this him/her self ; what is the trick if there is one,
any advice regarding this matter will highly appreciated
ardo is offline
#2 Old 07-09-2015
Vehicle: 2003 AMG SLK 32
Other Toys: '03 SL55 AMG, '07 Magnum R/T, 02 Tacoma 4x4, 1974 & 1994 Bronco, 2007 TRX 450r, 1985 ATC 350X
Did the CEL come on? Any codes? How many mile do you have? I recently had the same problem. I replaced the adapter plug and conductor plate. You should have been able to turn the adapter plug to lock. Being locked in 1st(limp mode), you will probably need to replace the conductor plate. Get 6quarts of tranny fluid, filter and pan gasket. Get a oil drop pan at the parts store(Autozone). It looks like a huge cookie sheet. You'll need it while you have the valve body out. The tranny will continue to drip from all over while you are working on the conductor plate. I bought a dipstick. They sent the wrong one. I used it anyhow. I put it in the tube and marked the spot on the dipstick that would indicate the correct amount (assuming I had the right amount). I used that when refilling. Good luck
SLiK 01 is offline
#3 Old 07-10-2015
Quoted: 27 Post(s)
Thank you for your reply, No cel code, I think I know the problem, ( I hope I know) when I pulled out the adapter, i pulled out only one O ring as I looked at the photos That Bazzle posted I saw there are two O rings, so I am assuming there is an O ring in there that did not come out this evening Ill find out, as for drip pan and dip stick I have them both, because a while ago I did partial fluid replacement.
Thank you for your input Ill post up the result later either tonight or tomorrow.
ardo is offline
#4 Old 07-10-2015
Quoted: 903 Post(s)
Clean the things thoroughly, put a little transmission fluid all around the bushing (especially on the o-rings) and the harness connector.
efair is offline
#5 Old 07-11-2015
Quoted: 27 Post(s)
update; all went well, the screw up was to O ring that I did not remove anyway there is a video on you tube a female mechanic is doing the same procedure videoed very well, if you do search replacing harness adapter on SLK. very impressive.
Thank you for your advice
ardo is offline
2005 SLK350 transmission downshift issue Iridium SLK R171 General Discussion 7 11-30-2017 02:40 PM
Headlight harness adapter Cheezhd SLK Parts Wanted 22 08-17-2013 03:57 PM
7G transmission service completed efair SLK R171 General Discussion 0 06-04-2012 02:46 PM
R170 harness adapter available blackdog General Modifications R170 0 06-28-2009 09:03 PM
