Nervous handling at speed - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By cliveandstella
  • 1 Post By Hal Adams
  • 1 Post By Skyflex
  • 1 Post By Skyflex
#1 Old 07-04-2015
Vehicle: 2000 (Facelift) SLK 200 Kompressor
Send a message via Skype™ to Skyflex
Hi folks. There are perhaps a few of these going around, but I am posting here as I cannot find the exact symptoms that I face. I have a 2000 200k and have shoddy handling at highway speeds. The particular problems I face are:
1. Steering wheel vibration at 120kmph at 6th gear and 3000 rpm. Specifically these parameters since if drop down to 5th and do 120 or more I do not experience such a severe shudder. Also at 6th if I drop to 110 and lower revs the vibration mostly goes away. At 6th and over 120 it seems equally shaky.
2. At anything over 90kmph the car seems nervous, as in I'm constantly making corrections. Also it seems to readily tramline with the uneveness of the road. Worth mentioning here that I run 17 inch rims with 215/45 front and 245/40 rears. Both are new Nokia Z lines though I had the problem with the older set as well.
My working theory after numerous attempts at balancing and alignment fixes is to do the following. Before I do I want to hear from the forum.
1. Check engine mounts
2. Check MAF to see if that is causing the 3k problem
3. Check/replace steering damper. The car has done 160k kms
Failing the above I just am clueless. P.S. I have also had the drag link changed recently as part of this endeavour. Happy to get your thoughts on the above 3 options and also anything beyond these that I might be missing. Thanks a ton!
Skyflex is offline
#2 Old 07-04-2015
Vehicle: 2005 SLK 200 Kompressor (R171) purchased in UK 2014
Other Toys: 1925 Citrśn 5HP, 1966 Sunbeam Rapier V, 2012 Peugeot RCZ
Quoted: 136 Post(s)
Hi there..
I have just done a quick search on slk-R170 general discussion: "vibration at speed" and found loads of threads.. here are just three of them...
https://www.slkworld.com/slk-r170-gen...ng-damper.html
https://www.slkworld.com/slk-r170-gen...tml#post334900
https://www.slkworld.com/slk-r170-gen...tml#post269391
search it yourself and you may find the answer... hope so..
cliveandstella is offline
#3 Old 07-04-2015
Thanks for the quick response ?I think at least 2 of these were in my 'research' ? It seems increasingly like a steering damper change. Will try it out over the next weekend. Difficult to go 120 in the city!
Skyflex is offline
#4 Old 07-04-2015
Sorry those were simleys on my phone and not question marks!
Skyflex is offline
#5 Old 07-04-2015
Vehicle: 1999 SLK230
Quoted: 9 Post(s)
Hi SkyFlex. Certainly not an expert here - more just sharing my experience. When my engine mounts needed replacing - it was significant at all speed/rpm. Even idle. Think of it more sounding like a muffler issue. From my experience, I doubt engine mounts would only show at speed, it's more about all rpms.
Cheers,
Jay
Jay_Marchant is offline
#6 Old 07-04-2015
Quoted: 136 Post(s)
Hi Skyflex... did you look at all the other possibilities that come up on the Search facility... ?? there were loads...
Your problem could be caused by so many different things... need to rule out the easy/cheaper options first.. before you go spending hard-earned cash..
#7 Old 07-04-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
If you have vibration in the steering at certain speeds only, is due to something out of rotational balance on one or both front hubs. Look nowhere else if this is the case. Vibration through the seat indicates the same, but at rear.
Steering damper is only there to absorb road surface variations. It will NOT mask any balance issues. Sort out the balances before you spend unnecessary money on this.
Engine mounts, as already said, will be evident at all times, increasing with speed.
MAF will not affect handling, so you can rule this out.
'Tramlining' as a rule of thumb can be due to too high a tyre pressure, oversize (or undersize) tyres or geometrically altering the centre spot of the wheels - eg using spacers. If you also have poor self-centering steering, then I'd ask if you are using spacers. Then there is the alteration of kpi, caster and/or camber. It goes on…
hth
Skyflex likes this.
Hal Adams is offline
#8 Old 07-04-2015
Thank you everyone for your replies, I do appreciate you taking the time. I think I will start again with the balancing and try out a different local shop. Looks like my other theories didn't hold up to the expert scrutineering here! I will report back with progress over the next weekend. Have a good one!
cliveandstella likes this.
Skyflex is offline
#9 Old 07-04-2015
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Have you had the alignment checked against specifications/stock? I'm sorry, I have a 171 - are the tire/wheel combination you're using stock?
FUN 4 2
Der Flieger is offline
#10 Old 07-05-2015
They are not stock, but I believe they are within spec for the car. Will just do a full balance and alignment check across the board, but at a different place. Thanks for your input.
Skyflex is offline
#11 Old 07-06-2015
Quoted: 136 Post(s)
Hi there...
Please do let us know how you get on.... especially if you find out the cause and the cure...
It is so frustrating when someone starts a thread and then leaves us all wondering what happened ......
Good Luck..
ichris93 likes this.
#12 Old 07-07-2015
Quick update folks. I got the balancing sorted today, but also got told that the left front damper is completely shot and thst the others are close to gone. At a 170k kms I'm not surprised! I'm also not sure if this contributed to the problem of vibration. Rest assured I didn't want to test the car at 120kms with that problem to see if the vibration was fixed. I've ordered a new set of Bilstein B4s for all corners. Next update once they're in place. Cheers!
Skyflex is offline
#13 Old 07-07-2015
Quoted: 271 Post(s)
If I were you, I'd get the whole lot done - struts and all mounting points.
Yes they all contribute to some extent, so renew everything and then a proper balance on disc and wheels will see it back to original.
Doing bits here and there will, I am afraid, get you nowhere.
#14 Old 07-10-2015
Smile
Thanks Hal, I'll be sure to have that looked into. Interestingly, some of the mechanics here sway between saying nothing needs to be fixed or everything needs to changed! So it might take some convincing on my part for them to look
Skyflex is offline
#15 Old 07-21-2015
So - I got new set of dampers all around, including a steering damper. Had the suspension inspected and was given the all clear. Took it out on to the highway - and certainly the vibration seems have gone down, but it still doesn't inspire confidence. The steering just feels loose - like I am keeping it in check the whole time - or it will go all over the place. I am starting to doubt my own sanity now, in so far as, whether the issue is all in my head. A little earlier today I even got one of those road force balances sorted - apparently that was over spec for 3 of the 4 wheels. Will try it out over the weekend again. Closing question - does this loose feeling on the highway say anything to you? P.S. I am using stock pressures for all tyres.
Skyflex is offline
#16 Old 07-21-2015
Quoted: 1135 Post(s)
Your car should feel solid on the road .
Take it you got original alloys ?
Correct tyre pressure is crucial .
Wheel balncing
Front wheel bearings adusted .
And the usual suspension components .
And dont forget to check the rear part of your car !
Coil springs
Suspension etc
And after everything is done wheel alignment .
Failing that test drive another slk then compare .
Delucas is online now
#17 Old 07-21-2015
Quoted: 271 Post(s)
Did they not check/replace track rod ends, arm bushes etc? They should have.
If you are all the time 'checking ' the steering and it feels 'loose', then it could - note the word could - be steering linkage or track rod ends.
With engine off, is there any play in the steering wheel side to side? There should be none beyong a few mm. If there is, then go back and tell you chappies to do their work properly. If the wheel has no play, then check steering box mountings.
Your car should feel solid on the road. If you are not happy with it, then there is still something wrong. As Delucas advises above, find another car that has been well maintained and compare.
Fifteen temporary speed cameras raised 4.7M GBP in UK Berliner Heckflosse Off Topic 2 05-18-2015 06:02 PM
Speedometer top speed often exceeds reality jbanks15 Off Topic 19 03-05-2013 10:37 AM
Control Your SLK: Handling for Road & Track RacerCub68 Motorsports 19 07-16-2012 04:19 PM
Texas highway would be the first to allow 85 mph speed limit jbanks15 Off Topic 3 06-07-2012 10:43 PM
Speedtronic to limit valet drivers speed? nmslk General Discussion 9 01-03-2008 07:27 PM
