Leaking SLK 230 roof - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By El_Toro_33809
  • 1 Post By qikslk230
#1 Old 07-04-2015
Vehicle: 2003 SLK 230 (R170)
Hello, I own a 2003 SLK 230 it's amazing and I love it, but I have an issue with the vario roof. The car was sold to me as is. So apparently the roof was fine . The dealer tried operating it and it wouldn't go down and started leaking. The headliner from the sides is basically ruined. More on the the right passenger side. I knew it would be a little hassle but I live in Vegas and as of now it's 110+ degrees. So at first I didn't mind not putting the top down. So a few weeks ago I tried just out I curiosity to put the roof down and it happened as so:
Windows go down & side smaller windows go down, at the same time i hear the mechanism to start working, the trunk lid opens and lifts, (at this point I hear liquids squirt to then stop and then squirt again ) the top detracts from the windshield body frame, and the top folds neatly in the back and then the trunk closes and voila . It's a roadster! It would go back the same way as described. No lag whatsoever but noticed little bit of liquid build up in the headliner . Eventually I tried one more time. Windows went down again and stuff but this time the trunk lid took forever to open it took longer and longer and the motor of the roof sounded as if it was trying harder (accelerated) so I didn't bother and pushed back on the switch and close the trunk lid and the small windows went up. I tried again. the windows went down but this tome the trunk lod wast opening and the motor of the roof sounded too accelerated so i stopped pushed back and it was back to normal. After that I haven't tried putting the top down. Untold a few days ago. As soon as I pushed back the switch the motor sounded fine and the trunk lid opened normally but stopped there because I didn't want to go further. So whats my questions? well What's wrong with my roof? What can/how to fix it? And about the motor.. Could it be my car battery? Because it looks cheap (BS dealer) because after that. The SLK would start funny. As in the battery wa slow. I tested it and it discharges in the night. But after driving in the day the car starts fine everytime. It just in the mornings. Also when putting windows down and my gauge lights are on I see the dim when putting windows down. So when after operating motor could it be that it drains my battery? That the motor of the roof gets stressed? Thank you.
qikslk230 is offline
#2 Old 07-04-2015
Quoted: 6496 Post(s)
If you do not know the true status of the battery, get it really tested or just buy a new one. the slk needs a great battery, not a new battery.
if battery test great, try a battery reset
disconnect battery for a minimum of 30 minutes (remove neg)
reconnect
reset clock
try roof
#3 Old 07-04-2015
El_Toro_33809's Avatar
Quoted: 86 Post(s)
+1 on what Jeff said in the battery.
On the top, the latching cylinder in the headliner needs to be repaired. That can be done without completely removing it from the vehicle and the seals can be ordered from eBay, and they should come with instructions. You will have to remove the headliner and get the cylinder loose from the roof, but you and keep your lines intact. Besides the seal, you will need some hydraulic fluid for the pump (and perhaps a syringe and some tubing to get the fluid in the pump). On the roofs we have worked on, it has taken quite a little while for the lines to self-bleed and get the roof back up to speed.
Good luck,many happy 4th of July,
Tim
ichris93 likes this.
El_Toro_33809 is offline
#4 Old 07-04-2015
reconnect
reset clock
try roof
Okay thank you, and I know for the fact is the battery, and again it's a cheap brand I don't even recognize it. Lol if so what are great batteries for the SLK out there? Thanks
#5 Old 07-04-2015
have you searched our wonderful site?
#6 Old 07-04-2015
Tim
Thank you! And happy 4th of July to both of you! I will be doing this before the next weekend hopefully, before taking the SLK on a trip. I have one more question though. What kind of hydraulic fluid do I get? One straight from the dealer? Or somewhere else? I heard the dealer is quite expensive on the hydraulic fluid, and do I have to empty the old fluid from the roof and pump? Thanks
#7 Old 07-04-2015
https://www.google.com/webhp?sourcei...ecommendations
#8 Old 07-04-2015
you're making me work hard
try our search feature
or go to google
type
site:slkworld.com r170 hydraulic fluid
gets this
https://www.google.com/webhp?sourcei...raulic%20fluid
#9 Old 07-04-2015
or go to google
type
gets this
Sorry! But THANKS! still getting accustomed to this site .__. But thank you!
#10 Old 07-04-2015
We are always going to help out, but we like to 'teach a man to fish'
#11 Old 07-05-2015
leapyfish's Avatar
Do not try to lower the roof any more unless you are repairing it.
You should replace the seals in all 5 cylinders at the same time rather than have another cylinder fail when you need it most.
If you have $$$ for a battery & hydraulic fluid go to a MB dealership & get it there, yeah its pricey but you are about to save $$$$ replacing the seals in the hydraulic cylinders yourself rather than replacing the cylinders.
Also, have a look through the all of the links in my signature.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 4 1 Week Ago 11:59 AM
SLK 230 Hydraulic Roof actuator repair Thud57 SLK R170 General Discussion 347 06-21-2019 06:16 AM
2002 slk 230 sticking roof Keep calm SLK R170 General Discussion 2 08-06-2014 06:46 PM
SLK 230 & 320 Mille Miglia Edition leapyfish SLK R170 General Discussion 0 05-06-2012 10:44 PM
SLK roof issues ron11son New Members Introduce Yourself Here 12 09-27-2011 10:57 AM
