Problem with Key - Mercedes Benz SLK Forum
 6Likes
#1 Old 07-02-2015
Vehicle: SLK 230 2003
Other Toys: Ducati Multistrada
Quoted: 7 Post(s)
Problem with Key
Well I recently got my SLK with only one key which was not looking that good but working.
I ordered a new plastic cover for it and tried to change the bits, I took the old one apart and removed the PCB and put in the new case, it did not work. I tried putting it back in the old case but it is still not opening the car, I have tested with a long press and the LED does work. To add to this, the barrel seems problematic so I can not use the blade to get in, any ideas ?
Ayal Zirlin is offline
#2 Old 07-02-2015
ichris93's Avatar
Quoted: 89 Post(s)
If you're in a situation where you just need to get into the car I believe that the trunk key hole will unlock all of the doors. I am not sure why your pcb isn't working though.
ichris93 is offline
#3 Old 07-02-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
You may need to reset it ?
Check out this post , it mentions resetting the key :
repairing broken W202 Key fob. - Mercedes-Benz Owners' Forums
Try loads of WD-40 or similar in the lock .
When you do the key fob change , make sure you transplant the transponder chip as well or the car won't start , more than one has lost it in the process ...
curro101 is offline
#4 Old 07-02-2015
Quoted: 7 Post(s)
where is the transponder chip ?
#5 Old 07-02-2015
Quoted: 6489 Post(s)
in these pictures
https://www.slkworld.com/slk-r170-cla...ll-holder.html
curro101 likes this.
#6 Old 07-02-2015
El_Toro_33809's Avatar
Quoted: 86 Post(s)
I believe it is a very small chip in the front iof the circuit board in the key fob.
Tim
El_Toro_33809 is offline
#7 Old 07-02-2015
Quoted: 7 Post(s)
Thanks, I have found the chip, but I am trying to open it with the old fob, old chip and old blade, the thing won't open, the only thing I can do is use the blade to open the boot.
#8 Old 07-02-2015
curro101's Avatar
Quoted: 528 Post(s)
Have you tried soaking the lock with WD-40 ?
curro101 is offline
#9 Old 07-02-2015
Quoted: 7 Post(s)
I have put loads of spray in the lock, the key only goes half way in, even after the soak and wait.
#10 Old 07-02-2015
Quoted: 7 Post(s)
Can someone tell me how the key works, is it IR, what does the transponder do(is it just for close up when starting the engine) what do the two buttons operate ?
#11 Old 07-02-2015
curro101's Avatar
Quoted: 528 Post(s)
If it's a one key fob , I think it's IR and I believe the receptor is around the interior light area . The transponder is for the electronis starting system and only affects staring the car . The two button remote is open & close .
curro101 is offline
#12 Old 07-02-2015
Quoted: 7 Post(s)
It is a two button fob, so you are saying the blade / transponder will start the car but the buttons will open close, so that operation is IR only?
How might I have damaged that ? or is it dependant on any other parts, sequence ?
#13 Old 07-02-2015
curro101's Avatar
Quoted: 528 Post(s)
If it's a two key fob , then it's RF , buttons for doors ( you should obviously be able to use the key to open the doors as well ) and transponder/key for starting .
Have you by chance been working on or near your aerial or doing any other sort of work on the car ?
curro101 is offline
#14 Old 07-02-2015
Quoted: 7 Post(s)
I have not been near the car at all recently, all I have done (at work) is take the fob apart and now put it back together. but it will not open the doors. By the way, if I ever get around to it, when reprogramming the key (pos 2, double click...) does that program the transponder and IR ?
#15 Old 07-02-2015
curro101's Avatar
Quoted: 528 Post(s)
The sync proceedure for your remote should be this :
This resyncs the remote , which in the two button case is RF not IR .
The transponder is coded to your car from factory and doesn't change .
It's possible that whilst transferring the internals of the remote that something has been damaged and doesn't work because of that ...
Keys if dropped etc can just stop working , they can be quite delicate !
Unfortunately as you only have one key , you can't try the spare which is the usual first step , you might have to order a new one to really check if the actual key is the problem or something else , it's always a good idea to have two just in case ..
curro101 is offline
#16 Old 07-02-2015
Quoted: 7 Post(s)
Any idea what a key would cost or best place to get one, what is the procedure for getting one made ?
#17 Old 07-02-2015
ichris93's Avatar
Quoted: 89 Post(s)
I believe the only place that can make you a key is the dealer and they have to order it. Unfortunately I believe your car also has to be present for VIN verification.
ichris93 is offline
#18 Old 07-02-2015
Quoted: 7 Post(s)
Well thats a bitch, thanks for all the info tonight.
ichris93 likes this.
#19 Old 07-02-2015
ichris93's Avatar
Quoted: 89 Post(s)
z
That could be a MB USA policy though.
ichris93 is offline
#20 Old 07-02-2015
curro101's Avatar
Quoted: 528 Post(s)
Your best bet is to ring your local dealer and see what they say ...
curro101 is offline
stuck in park + ignition key problem jvs New Members Introduce Yourself Here 23 04-20-2014 12:45 PM
No Acceleration, OBDII Code P0120, Steps to fix the problem pkondilas SLK R170 General Discussion 6 01-30-2012 04:55 PM
Hi from Australia (problem with R170) Giacinto New Members Introduce Yourself Here 16 12-21-2011 07:07 AM
