Battery Draw 3 - 4 volts or 350 mAmps - Mercedes Benz SLK Forum
  • 1 Post By DSSG
  • 1 Post By lannylord2000
#1 Old 06-26-2015
Vehicle: 2000 Mercedes SLK230 Sport
Quoted: 8 Post(s)
My battery in my 2000 MB SLK230 went dead Monday after washing the car on Sunday and that is it! Charged up battery and dead 2 days later without running it. It did start OK after charge. Now Friday and Autozone says battery good after charging so ended up putting Amp meter on and it is drawing 350 mAmps or 3 - 4 volts depending on the setup. I pulled all fuses and no change. Anybody got a suggestion?
Lanny
lannylord2000 is offline
#2 Old 06-26-2015
Quoted: 6489 Post(s)
1. get it tested at another place like pepboys,etc
2. cables ok? tight?
3. was alternator tested?
a. slks like a great/excellent battery. good battery does not cut it
#3 Old 06-26-2015
Quoted: 8 Post(s)
Power Draw
Thanks for the info, I definitely read your guys advice on batteries, but I would have changed it if I didn't have the 3-4 volt power draw and starts just fine with no indicators. Alternator not tested but probably my next step to look at? Hate car problems and I just went on vacation today for a week. I would rather drive it around and car show tonight, oh well that's life.
Lanny
#4 Old 06-26-2015
Others will jump in with ideas.
#5 Old 06-26-2015
Quoted: 8 Post(s)
Alternator wire
I disconnected alternator wire on module next to battery where the positive side of battery goes and the voltage dropped to .15 v vs 3.5v volts. So headed to that area and see what I can find. Hopefully just need new alternator to fix short in car.
Lanny
#6 Old 06-26-2015
Quoted: 8 Post(s)
Voltage Regulator testing
Does anyone have a pinout for the voltage regulator to test it or how to test it?
Lanny
Either I get alternator $164 bucks or voltage regulator $16 off Ebay
#7 Old 06-26-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
Why don't you just test the alternator with a volt meter while it on the car?
There is another test for the battery:
BTW, if the alternator checks out OK, then you also know that the voltage regulator is OK, since it is internal to the alternator.
Easy peasy!
lannylord2000 likes this.
DSSG is offline
#8 Old 06-27-2015
Quoted: 8 Post(s)
Alternator Problem
Thanks DSSG for the video. I confirmed the alternator not charging using the video you provided. I included picture of the setup I used to determine the voltage parasitic draw I was having. I used a 1 ohm 10W ballast resistor to hook between ground cable and ground on the battery and set multimeter for DC volts. As you can see I had a 3.29V DC drop which was killing my battery overnight and the video DSSG confirmed I had no charging after I started it. The alternator comes in today I hope and I can get the car back on the road. Also, used the setup to see your amp draw as well where you hook your multimeter on amps between battery negative and negative cable. It read 350mAmps.
Thanks all,
Lanny
#9 Old 06-27-2015
Quoted: 8 Post(s)
Alternator was the problem
Thanks for all the help, put in new alternator from OReillys and seem back to normal. Couldn't find the torque values for the bolts so if anyone knows I appreciate it.
How I chose the new battery for my SLK Lioninstreet SLK R171 General Discussion 40 07-01-2019 03:16 PM
3 Days and MB Dealership cannot find cause of battery drainage (SLK 350 2006) mnjg General Discussion 9 02-24-2011 08:50 PM
