changing turn signal assembly next to the headlight - Mercedes Benz SLK Forum
#1 Old 06-25-2015
Vehicle: '02 SLK32 AMG in "naked" MB color that was used for getting a car's weight to be under a HIGH number
Other Toys: bike as in road bike, 13lbs. A beautiful machine!
Quoted: 46 Post(s)
I lost a turn signal lens so I bought a new assembly. How is the old assembly removed? I see a small square opening in the bottom of the rear reflector with what appeared to be a tab. Just touched it with a screwdriver and the tab either broke or simply "hid" on me. Anyone know how to change this turn signal assembly, getting the old one out especially. Seems to slide out but that tab that is gone must have had something to do with it. No way to get at it from inside the engine bay. Some help please as a search here showed no match! THX mark
Sweet04 is offline
#2 Old 06-25-2015
Professional Troublemaker
MikeWest's Avatar
Quoted: 19 Post(s)
It really sounds like Mark is trying to remove the turn signal pod that is part of the headlight assembly.
The entire headlight assembly needs to be removed, it is 3 screws and then it easily slides out. The turn signal pod attaches to the side. I can't paste search results from this current computer, so all I can say is look in the Mod section for people with Spyderlight installations, someone has taken pictures of the steps. I swapped out my headlights, that is how I know it is 3 screws and a really simple procedure. I just didn't write it down
Living in New Jersey, currently SLK-less
MikeWest is offline
#3 Old 06-25-2015
Quoted: 6489 Post(s)
Thanks Mike
I just reread it
Pelican Technical Article - Mercedes SLK 230 - Head Light and Turn Signal Light Replacement
#4 Old 06-25-2015
Quoted: 46 Post(s)
The turn signal housing can be removed in a matter of seconds, simply by pressing its retaining lug with a screwdriver, sliding the light forward, and unplugging the electrical connection.
My turn signal and headlight are 2 separate assemblies though I know they can be bought as one. In the write up that Jeff posted I copied what needs to be done above. Problem where is the retaining lug? I think it is between the assembly and the fender from a pic I have seen. I may wait until I see the new assembly in a day or two. Thanks guys.
Anyone know where to get inexpensive headlight assemblies for an SLK(mine) with the XENON lights? I don't know why the assembly, no ballast or bulbs should be more than the regular lighting. I am talking the lens(mine are faded/cloudy) and the reflector. Then use the same bulb and ballast/all old parts except for the lens and reflector. What am I not understanding? Can't see paying hundreds for a XENON assembly with no hardware! Mark
Sweet04 is offline
#5 Old 06-25-2015
Quoted: 46 Post(s)
My headlight and turn signal are two different assemblies. I now have the new turn signal assembly in hand. It has 2 1" long "spikes" and 2 clips that would attach on the headlight assembly. There is also an odd circular section right next to the prongs for the wiring harness. the spikes have movable clips next to them also that slide. I'm sure this is simple once it is done once. i need assistance with the "once"! I'll check on removing the entire headlight.
On Benzworld they show where a screwdriver would go, somewhat, to release a clip that allows the signal assembly to be removed without the headlight! back out there!
Sweet04 is offline
#6 Old 06-25-2015
Vehicle: 2002 slk 230
Quoted: 21 Post(s)
I have seen a video on you tube on how to do this,just search for headlight removal and it should appear.
allenhh is offline
#7 Old 06-25-2015
Quoted: 46 Post(s)
I got it. Just pop the hood and near/above the signal assembly is a circular opening. Just push down with a screwdriver or pencil and the signal pops out. Done.
I would suggest that if anyone needs to change a light to get genuine Bosch as I did not and the quality and fit could be better. Mark
Sweet04 is offline
How to fix turn signal hyperflashing if you have LEDs JaysonM SLK R170 class DIY 4 03-03-2015 12:47 PM
Turn signal assembly replacement alido pavan SLK R170 General Discussion 1 05-22-2014 05:26 PM
98 SLK230 turn signal problem yachtdude SLK R170 General Discussion 3 03-27-2014 11:26 AM
Right Turn Signal Problem onenobx New Members Introduce Yourself Here 12 07-25-2013 12:00 PM
Turn signal in mirror, right - Malfunction gdb069 SLK R171 General Discussion 8 03-05-2012 01:21 PM
