Power Roof Switch Replacement - Mercedes Benz SLK Forum
#1 Old 06-24-2015
Vehicle: 2004 SLK320
Other Toys: 1100 V-Star Motorcycle
Can anyone help me replace a broken power roof center console switch on a 2004 SLK 320? The back clip (or whatever holds the switch in place) is broken and if not careful the switch falls down into the console. I think if I can get the center console off I might be able to fix or replace it.
mtnman is offline
#2 Old 06-24-2015
Quoted: 903 Post(s)
You'll have to take the center console off... Start with the two nuts in the console under the armrest, then the gearshift surround.
efair is online now
#3 Old 06-24-2015
leapyfish's Avatar
Starting with pic "a"
Gently pry up the chrome surround from the gearshift.
then gently pry the outer surround,
start at the outer center & work your way around it ( it will slowly come up) that will expose 2 screws that attach to the lower section of the console. (pic 24 here Dashboard and Center Console )
Then pic "b"
Then you need to remove the grip on the hand break, a few drops of liquid soap between the grip & mechanism wil help alot to get the grip to slide off.
Theres a flap of carpet at the rear of the cubby that you peal back to expose 2 screws, undo those screws & the 2 at the front of the console near the gear shift.
Gently lift the section around the hand break lever.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#4 Old 10-21-2018
Vehicle: 1998 SLK 230 _and_ 2001 SLK 230
Quoted: 9 Post(s)
Thanks, leapyfish!
I have this same problem. Should I order a new switch before I remove the console cover? Or is it likely repairable, given that the switch itself works.
myf16 is offline
#5 Old 10-23-2018
leapyfish's Avatar
Originally Posted by myf16 View Post
Thanks, leapyfish!
If the switch works, The problem may be the plastic has become brittle and the switch needs to be glued in place.
If thats not the problem you can still drive with the console taken apart while you wait for a new switch.
Vario roof
R170 & R171
SLK 230 320 32AMG
#6 Old 10-28-2018
Quoted: 9 Post(s)
I had no problem removing the rear console cover. The switch had simply popped out. Maybe someone sat on it? I added a couple dabs of glue before popping it back in.
It was time to repaint the ivory interior plastic, so this provided a great opportunity to make the console look like new. I used white lithium grease to ease reinstallation of the brake handle cover.
myf16 is offline
Helpful links and info for combination switch (Turn Signal Lever) replacement mistergoodpepper SLK R170 General Discussion 1 10-16-2014 07:13 AM
Roof Closing Issue dterry SLK R170 General Discussion 4 07-10-2013 06:35 AM
171 Power Seat Switch (passenger side) dougrobling SLK Parts Wanted 1 02-13-2012 06:04 PM
Brake light Switch replacement foreign freak SLK R170 class DIY 0 07-03-2011 12:27 AM
Multifunction switch replacement phdldc SLK R170 General Discussion 0 08-18-2010 09:47 PM
