Proper trans fluid level - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By MortarH3ad
  • 2 Post By cnovack
  • 1 Post By jbanks15
  • 1 Post By Aycee
#1 Old 06-19-2015
MortarH3ad's Avatar
Vehicle: 2001 slk 230
Jeff, don't crucify me but my time is limited and I wasn't sure where to post.
I got my dipstick today and checked the level while cold. It was way up on the stick and the color was a murky brown color. It smells OK and doesn't seem too thick which leads me to believe the previous owner had a Limp mode and tried to just add red trans fluid To the common factory green fluid to remedy the problem. I'm thinking about draining it to the proper level just to see if there's a chance to clear the Limp. I'm planning to do the conductor plate anyway but just want to see if an overfill might have been the problem. Or should I just not bother messing with it and swap all the fluid and do the plate? I know that sometimes it's just a transmission code holding it in Limp but I've read about guys having it jump out after they changed the plate or got proper fluid levels. Also can Limp cause the fluid to appear as if it's overfilled? Sorry for the long rambling post and the over use of fluid......
Fluid...
MortarH3ad is offline
#2 Old 06-20-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
A brown color is the first signs of major trouble ahead in the transmission. At this point about all you can do is change the oil and filter. Eventually, it'll fail and you'll need a rebuild.
DSSG is offline
#3 Old 06-20-2015
cnovack's Avatar
Vehicle: 2014 SLK55 AMG
Other Toys: 2012 ML350, a fresh water boat and a powered parachute some years ago...
Quoted: 66 Post(s)
I think we all have been down that road.
jbanks15 and MortarH3ad like this.
The Black Adder
  • Obsidian Black Metallic with Bengal Red Premium Leather interior
  • AMG Handling pkg
  • Magic Sky Control
  • Multimedia pkg
  • Lighting pkg
  • Keyless-go
  • AMG Illuminated Door Sills
  • Digital Dual-Zone Climate Control
  • Black Ash Wood Trim
  • AMG 18" Multi-Spoke Alloy Wheels in Black Matte
Pimpin' my ride
  • AMG AFFALTERBACH Chrome Steering Wheel Badge
  • WINDRESTRICTOR Option 12
  • 1 ea - 7 inch Hula-Hula girl
  • South of the Border car magnet
  • Bigfoot car magnet (coming soon!)
cnovack is offline
#4 Old 06-20-2015
Quoted: 903 Post(s)
Do you have a check engine light with the limp, and if yes, what are the codes?
efair is offline
#5 Old 06-20-2015
Quoted: 6496 Post(s)
Ouch! I've been skewered again!
cnovack likes this.
#6 Old 06-21-2015
MortarH3ad's Avatar
Yeah I got Limp and p0758 ( solenoid code which popped up after I changed the conductor plate) p0720 p0705 p0500 p0600. I switched out the conductor plate and filled the trans to the proper level and though still in limp mode it switched between reverse and drive smoothly without the jolt it had before. Also the pan had no debris or particles on the bottom. The conductor plate that I took off actually looked great as well. The plug had a little fluid in it but I changed it and cleaned the other end with contact cleaner. Didn't seem like it had wicked up to the time. I'm hoping a code reset will get her out of limp. I'm hoping to have a multiplexer and software this week.
#7 Old 06-21-2015
Quoted: 903 Post(s)
That's more than the typical TCM failure presents.
Have you looked at the TCM connector? Was there any discoloration or oiliness in the foam where the wiring comes through the floorboard?
efair is offline
#8 Old 06-21-2015
MortarH3ad's Avatar
Looked surprisingly clean when I took it apart.
#9 Old 06-23-2015
Aycee's Avatar
Vehicle: 2002 Blue SLK 320
In your 1st post you say the level was checked cold. The fluid level should be checked when the engine/gearbox are at operating temp, 80 degrees C. I use an infra red thermometer to check as the gearbox takes a while to warm up. Fluid level is critical to correct operation.
MortarH3ad likes this.
Aycee is offline
Proper way to check 722.6 fluid level jpowelso SLK R170 General Discussion 22 06-26-2015 09:05 PM
The 7-G Tronic Transmission Spec 722.9 DSSG SLK R171 General Discussion 31 01-26-2015 02:55 PM
What IS the correct way to check roof pump fluid level? PaulRUK3 SLK R170 General Discussion 2 10-04-2013 10:15 AM
Check Auto Trans Fluid Level - 2006 - 350 JohnTX SLK R171 General Discussion 7 03-23-2010 07:50 PM
