Roof wont close,abs lights on auto box won't change? - Mercedes Benz SLK Forum
  • 2 Post By curro101
#1 Old 06-18-2015
Vehicle: 2000 SLK200
Hi Guys,
I have a problem with my SLK200 which has been off the road over the winter. The Abs lights are on the roof wont go up and the autobox won't change up seems to be stuck in 3rd gear. I have read alot of threads on here about similar problems and think its the brake switch or Abs sensor? Anyone have any advice or suggestions as to the cause of the fault?
Tonyb is offline
#2 Old 06-18-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
The roof is connected to the ABS system due to speed sensors .
Have you checked all the fuses and reset the steering wheel full right and full left if you had the battery off ?
Have you tried a battery reset and is the battery 100% ?
Can you get the codes read with a diagnostic machine of some sort ?
jbanks15 and Tonyb like this.
curro101 is offline
#3 Old 06-19-2015
Thanks for your reply, yes tried the usual things, getting a code scanner monday.
What is battery reset?
Tonyb is offline
#4 Old 06-19-2015
curro101's Avatar
Quoted: 528 Post(s)
Originally Posted by Tonyb View Post
Remove the negative for 30 mins or so .
curro101 is offline
#5 Old 07-02-2015
So bit of an update on this, I found a guy locally with star diagnostics but hes on holidays till 7th july. I have tried several things such as clean Abs wheel sensors and replace the brake light switch with no luck the Abs/Bsr light it still on, but I have noticed when driving that if I accelerate hard from a standing start it goes off, or if I turn the ignition off and back on while the car is moving slowly it clears might stay off all day or for 2mins!
If anyone can suggest a fix or something to try? Car is my daily driver atm.
Tonyb is offline
Unlock/Lock Chirp spence46 SLK R171 General Discussion 75 06-29-2014 02:02 PM
anything to change our front lights rnbguy General Modifications R171 5 07-26-2009 02:50 AM
Auto setting for lights alex c SLK R171 General Discussion 18 03-03-2008 08:54 AM
