Inside map lights - Mercedes Benz SLK Forum
#1 Old 06-18-2015
jnc1948's Avatar
Vehicle: 2004 slk320 91,000 miles black/charcoal
Quoted: 33 Post(s)
Inside map lights
My left inside map light when out...Right one still works... Looks like the whole things will too come down just to replace the bulb..Is there a easy way?
Is it a DYI or do I have to take it to the dealership?
jnc1948 NC
jnc1948 is offline
#2 Old 06-18-2015
Quoted: 6489 Post(s)
did you search yet my young friend?
https://www.slkworld.com/new-members-...searching.html
see my search results below
go to google
type
site:slkworld.com r170 replace interior bulbs
or similar words
https://www.slkworld.com/slk-r170-gen...ight-bulb.html
Replacing Interior Lights - Mercedes-Benz Forum
#3 Old 06-18-2015
jnc1948's Avatar
Quoted: 33 Post(s)
I am afraid I will break something.... being a 2004 unit and the plastic may break easy... I an getting 2 bulbs tomorrow from the dealership and may give it a try wish me luck...
jnc1948 NC
jnc1948 is offline
#4 Old 06-18-2015
use small jeweler's flathead screwdriver like it says to pry
#5 Old 06-18-2015
keith1275's Avatar
Vehicle: 2014 SLK 250D
Other Toys: classic mini cooper.
the plastic cover detaches - ease it out from the rear with a flat bladed screwdriver.
then using a phillips head screwdriver remove the two screws holding the unit to the body. the bulbs twist and remove.
In my case, the bulbs were fine, the alloy bulb holder had become loose breaking the circuit. I simply bent it back a bit to make a good contact. I used vaseline on the contacts and re-assembled.
oh i hoovered the spider out of the cavity too!
keith1275 is offline
#6 Old 06-18-2015
jnc1948's Avatar
Quoted: 33 Post(s)
The cover includes the mic for the Tele Aid, and I imagine quite different from the simple rectangular one.
So are the steps different? Please advise again jbanks15 Thanks MSGT
jnc1948 NC
jnc1948 is offline
#7 Old 06-18-2015
well it's been 10 years since I had a r170 but i don't recall the mic being in the area that you pry off to replace the bulbs. current r170 owners will chime in
#8 Old 06-18-2015
keith1275's Avatar
no mic on my euro-spec r170 - no remote door opener either that i could see.
#9 Old 06-18-2015
Yes, it just pries off the white matte plastic lid exposing the inside of the lamp assembly.
You will find a plastic 'bulb cover' on each one of these lamps that you can use a small flat screwdriver to unlatch it from the side. (it interlocks with the grey plastic base).
Now... this is a bit delicate depending on how old /used these were, as the gray plastic might have become brittle.
The bulb is just a pull out motion, not a 'twist on'... twisting it will cause the bulb holder to come loose from the base.
Suggestion on my side... when you do this... change both of them because when I did it I realized they had different tone and intensity which bugged me a lot and had to do this twice.
#10 Old 06-18-2015
Pelican Technical Article - Mercedes SLK 230 - Dome Light Replacement
#11 Old 06-19-2015
Quoted: 20 Post(s)
I do have a 2001 slk320 which is different from the 230. If it is anything like mine. You have a center button that operates both sides of the light. You need a small screw driver and pry from the edges (where you see the slots). Plastic should pop out. Bulbs are covered by a difusure to spread out the light pattern. Clip out the difuser and you will have access to the bulbs. I switched my lights out for 194 LED's. No need for canbus LED bulb. You won't get a light out indicator.You can pick these up at Autozone or Pep Boys (or anywhere). Reverse process to put everything back.
Joeb77 is offline
#12 Old 06-20-2015
Wizard of ID
tcrankwa's Avatar
Quoted: 22 Post(s)
Jeff, you never cease to amaze me...
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#13 Old 06-23-2015
jnc1948's Avatar
Quoted: 33 Post(s)
Update...while trying to remove the plastic from the map light area must have jar the bulb or something it came back on..
SO I did not have to replace the lamp bulb. The question is I wonder when it will go out or happen again. So now I have two new bulb
I guess maybe it came lose when ridding over rock and maybe hit a pot hole or some thing... But it working now again.
Thanks for all the tip and instruction on how to replace the bulbs..
jnc19481948
jnc1948 is offline
SPYDER Headlights Durkatlon General Modifications R171 374 08-27-2018 08:33 PM
New Spyder Lights/Repair Bumper/Marker Lights Philo SLK R170 class DIY 11 03-03-2015 12:37 AM
none of the inside lights work offdepp SLK R170 General Discussion 3 11-27-2012 01:24 AM
How to have the main lights + the LED lights on at the same time? addictive SLK R172 General Discussion 7 08-09-2012 05:29 AM
lights stay on, key remote not working, code on radio jvbutter SLK R171 General Discussion 0 01-15-2011 11:24 PM
