Intermittent problem... - Mercedes Benz SLK Forum
  • 2 Post By helidoc
#1 Old 06-15-2015
helidoc's Avatar
Vehicle: 2001 SLK230
Other Toys: 20 ft Cape Horn
Hope to get input on current problem... SLK 230/2001... Car cranks and idles roughly. Also when running down the road at times it cuts back to 20- 30 mph and won't go any faster... I scanned and got generic codes PO 102-mass/volume airflow A circuit low input..P0457-evaporative emission system leak detected...P0101-mass or volume air flowA circuit range/performance....P0455-evaporative emission system leak detected (gross leak/no flow)..that being said I checked Mass air flow sensor, it was clean and dry...I did discover that the harness connector for the cam position sensor was broken (from age and heat I suppose)..harness will plug in but not lock in place...Could this be the problem? Any ideas?
helidoc is offline
#2 Old 06-15-2015
Quoted: 903 Post(s)
Probably an actual MAF problem - did you check its wiring too? Try cleaning it?
The EVAP errors are completely separate and have nothing to do with running rough.
efair is offline
#3 Old 06-15-2015
helidoc's Avatar
I did use electrical cleaner on the mass airflow sensor... Wiring looked good.... Inside of sensor appeared clean and dry(no oil present).
helidoc is offline
#4 Old 06-18-2015
helidoc's Avatar
Problem solved:
Final results after Mass Airflow sensor change...car initially had same rough idle but ran out good on road test... Cleared codes and rescanned engine... All good, codes gone, engine idles perfectly.. Road test 0-60 mph about 5 seconds.. In the lessons learned department... Codes have to be erased or computer still thinks the problem exist.. Is that correct? Thanks for the input..
leapyfish and tcrankwa like this.
helidoc is offline
#5 Old 06-18-2015
Quoted: 903 Post(s)
Great news then!
Some codes clear by themselves, others don't.
efair is offline
Intermittent seat adjustment problem. Seat relay fix. JaysonM SLK R170 class DIY 46 03-29-2019 03:34 PM
Conductor Plate Problem; shady service rep... What to do? Th3120ck General Discussion 35 02-12-2012 04:41 PM
Bluetooth Problem | iPhone4 | 2009 SLK | Intermittent connection loss ThalwilCanuck SLK R171 General Discussion 9 09-14-2011 05:11 PM
