Top stops half way Problem - Mercedes Benz SLK Forum
#1 Old 06-15-2015
Vehicle: Mercedes Benz SLK 230 2000
So I see a lot of people are having problems with the top going down. so my problem is when I hold on the switch to engage the top to go down it stops half way. which then I have to release the switch and hold the switch again to make the top go down. So. sometimes it stops half way and doesn't want to go down. which then the top doesn't want to go back up and stays half way. I have to take out the key to release the pump for it to go back towards the windshield to close the top. also if I don't mess with the top for a couple of days it well go all the way down and close and come back up and completely close. but when I try to put the top back down it gets stuck half way and doesn't want to go down or go back up. Please help I haven't seen anyone with this problem. I hope it all makes sense.. I have replaced the relay to the top hydrolytic pump. Am afraid its the pump that is going out for the top.
SLKGuY is offline
#2 Old 06-15-2015
Quoted: 6483 Post(s)
and you checked the troubleshooting guides?
https://www.slkworld.com/slk-r170-cla...leapyfish.html
https://www.slkworld.com/slk-r170-cla...ostic-aid.html
#3 Old 06-15-2015
Hello Jbanks, yes I have and I didn't find anything that could help me.
SLKGuY is offline
#4 Old 06-15-2015
Members will chime in I am sure
and how old is the battery?
#5 Old 06-15-2015
Thanks Jbanks! I believe the battery is pretty new. but let me go out and check real quick..
SLKGuY is offline
#6 Old 06-15-2015
Looks like the battery is from December of 2009.... haha.... and the fluid for the pump looks good. its not below the mark or above the mark.
SLKGuY is offline
#7 Old 06-15-2015
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Have you greased all the pivot points on the roof mechanism ?
curro101 is offline
#8 Old 06-15-2015
so battery is 6 years old? get it tested.
Craige will vouch for a great battery. a recent thread had same issue and it was the battery needed resetting
https://www.slkworld.com/slk-r171-gen...p-problem.html
#9 Old 06-15-2015
Ok thanks J, tomorrow I well go out and buy a new battery. and yes it has been done when I bought it, I greased everything that I thought needed to be done.
SLKGuY is offline
#10 Old 06-15-2015
get the battery tested first. don't want to get a new battery if it tests great/excellent.
SLK loves a great battery, not a good one
grease what has to be greased, not what you think needs it
https://www.slkworld.com/226839-post1.html
#11 Old 06-23-2015
Battery tested ok, I'm thinking its one of the 6 relays for the top...
SLKGuY is offline
#12 Old 06-23-2015
relies? replies? oh! relays? sensor or switches?
#13 Old 06-23-2015
Quoted: 899 Post(s)
Describe what you mean by "half way"? Or exactly what state is it in when it stops working?
efair is online now
#14 Old 06-25-2015
Hello Efair, thanks for the post, when holding the switch up to put the top down, it stops where its about to fold and just stays there. then I release the switch and which then I pull up on the switch again and the tops starts to fold into the trunk or just stays at that position where its about fold in.
below is the best picture I could find online what it looks like. to afraid to mess with mine till I take the trunk apart and replace relays.
SLKGuY is offline
#15 Old 06-25-2015
curro101's Avatar
Quoted: 528 Post(s)
It looks like it would be the relay on the roof pump , but you said you replaced it , no ?
Did you use a new one from Mercedes ?
Hace you greased all the moving parts/joints ?
curro101 is offline
#16 Old 06-25-2015
The only relay I replaced was next to the hydraulic pump in the trunk.
SLKGuY is offline
#17 Old 06-25-2015
curro101's Avatar
Quoted: 528 Post(s)
That's the one , the roof pump on the right in the trunk !
Did you replace it with a new one from Mercedes ?
curro101 is offline
#18 Old 06-25-2015
hmm Nope. bought the relay from Auto Zone.
SLKGuY is offline
#19 Old 06-25-2015
curro101's Avatar
Quoted: 528 Post(s)
Might be worth getting an actual Mercedes one to ensure it's a 100% match ?
Check this out as well :
Pelican Technical Article - Mercedes SLK 230 - Convertible Vario Top Hydraulic Pump Unit Service
curro101 is offline
#20 Old 06-25-2015
curro101's Avatar
Quoted: 528 Post(s)
Found this as well :
Electric windows are fine the roof gets half way - Fixya
curro101 is offline
SLK Retractable top problem tgerber SLK R171 General Discussion 8 02-20-2014 06:19 PM
Top Issue: Bad switch or user error? conleyjb SLK R170 General Discussion 6 04-10-2013 11:41 PM
Problem with my SLK top getting stuck up & down CushyCouple New Members Introduce Yourself Here 21 04-24-2012 08:59 PM
Slight Problem With Top Display TrevF General Discussion 22 02-15-2012 12:14 PM
