help with leak from cam shaft adjuster - Mercedes Benz SLK Forum
#1 Old 08-26-2010
Vehicle: 2000 SLK230
how do i fix these oil leak coming from the camshaft adjuster? the camshaft adjuster is just 5 months old
entrepid is offline
#2 Old 08-26-2010
Vehicle: 2001 SLK320 IRRIDIUM/CHARCOAL
Other Toys: 2003 HONDA VTX1300 RETRO
INTREPID,
I replaced my Camshaft adjuster magnet about 6 months ago. Yesterday I took the car in for a brake light switch failure and they replaced the cam adjuster again at no charge covered under part warranty. Check with Mercedes, it could be udner a part warranty.
RQUICK1 is offline
#3 Old 08-26-2010
do i really have to replace it? idont think it has warranty because i just bought it from a friend.
entrepid is offline
#4 Old 08-26-2010
Vehicle: 1999 model SLK 200 (136 HP)
Other Toys: Ural with sidecar
The problem is most probably not the camshaft itself but the gasket... Just change the gasket...
kole301 is offline
#5 Old 08-26-2010
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 119 Post(s)
Or if the gasket looks good, just smear a bit of Blue Hylomar/Red Hermatite/Silicon RTF/Gasket Cement on either side of the gasket, then replace it.
Woolly is offline
#6 Old 08-28-2010
thanks guys.. when i detached it i noticed that there is no gasket.. is that normal?
entrepid is offline
#7 Old 08-28-2010
Quoted: 104 Post(s)
That is normal, i replaced mine three years ago and used a high temp silicon to seal it. So far it has been bone dry.
#8 Old 09-05-2010
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
If the leak is only at the bottom you can remove it and use a non-silcone sealent and put it back on. If there is oil in the wire connection you will need to replace it.
If in the USA and a 2001 to 2004 there is a recall and the dealer will replace and put an adapter in the wiring to stop oil wicking into the wire harness.
Gbarringer100 is offline
#9 Old 09-06-2010
Vehicle: 2012 SLK55 AMG, Diamond White
Quoted: 82 Post(s)
I have what looks like a tiny leak - has probably been this way for ages. The funny thing is, it isn't running down. It is coming out at the 10 o'clock position and going off to the left. No oil on any of the wires though, so not too concerned.
Captainrave is offline
#10 Old 09-06-2010
Quoted: 99 Post(s)
You need to pull the wire connector to cam adjuster and see if you have oil inside it. Oil will wick inside the actual wire under the wire covering. You willl not see it. For the 2001 and up there is a part that can be installed to prevent this. On pre 2001 at the cam adjuster you can cut the wire cover and mash the wire flat and then solder over the wire about 1 inch long and then tape the wire. You need to do both wires. Making a solid wire and not strands will stop the wicking
#11 Old 10-24-2015
Vehicle: 2003 SLK 230
Other Toys: C 240 MB
I took mine off and put on a sealant. When I went to start the car a made a bad noise. I redid the seal now the car cranks but it doesn't turn over
Z-11 is offline
Drive shaft center bearing help. gringott SLK R170 General Discussion 15 02-12-2018 05:09 PM
oil leak CNC44 SLK R170 General Discussion 4 09-04-2012 06:23 PM
