Left brake light out - bulb is fine - Mercedes Benz SLK Forum
 15Likes
#1 Old 05-21-2010
My left brake light is out, but the bulb is not burned out. Changed the bulb anyway. Still doesn't work.
Where else can I look for the problem?
thanks
benzer102 is offline
#2 Old 05-21-2010
IIRC, there was a recall on the lamp holder for the tail-light assembly of the R170. The contacts were bad.
#3 Old 05-21-2010
Vehicle: 2003 SLK 230
Chats: 2
Too funny I just posted couple days ago about the same problem. LOL. Left tail lite, replaced bulbs, still nothing. A mechanic buddy told me it might be a bad ground somewhere but after hearing about that recall I'm inclined to just replace the whole thing and see what happens. Good luck. Let me know when you get yours fixed and I'll do the same.
elijahjm101 is offline
#4 Old 05-21-2010
Quoted: 6510 Post(s)
benzer102,
In addition, if you haven’t, please post your questions in the appropriate discussion forum for a quicker response.
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
#5 Old 05-22-2010
Vehicle: SLK320 sport
Had the same issue. I didn't want to buy a whole new lamp housing so I pulled the left tail light out and noticed some corrosion on the contact where the bulb was (for me it was the top brake light) so I took the bulb out and sanded the contact on the bulb holder and on the tail lamp assembly. Both contacts are back to natural color and work great! Not sure how long this will last, but I am saving up for some smoked LED tail lights just can't afford to change both housings now!
Guy Galt likes this.
mattmintun is offline
#6 Old 05-22-2010
Founding member #7
mtiede's Avatar
Vehicle: 2017 SLC 300R
Quoted: 25 Post(s)
Depending on the amount of corrosion, rather than sanding, you might just try a pencil eraser. That is sometimes abrasive enough to clean contacts without abrading away material.
mtiede is offline
#7 Old 05-22-2010
Over 100,000 miles!!!
SLKman's Avatar
Other Toys: Just my SLK
Chats: 59
Call your local Mercedes dealer and give them your vin # to see if you can get them replaced for free.
There was a recall.
leapyfish likes this.
SLKman is offline
The Following User Says Thank You to SLKman For This Useful Post:
#8 Old 05-24-2010
Chats: 2
Took out left tail light bulb and noticed (now that you guys said to look for it! thnx) that there was some corrosion on the ground connects! Took a knife and scraped it all off and works fine...for now! So just to be safe I took out all the bulbs and did the same for all of them. Hope this helps!
#9 Old 05-24-2010
^^ glad it worked!
#10 Old 03-23-2011
Vehicle: SLK AMG 230 1999
Is anyone has tried just to change the bulb holder? It should not be very expensive, just a little piece of plastic...
bars is offline
#11 Old 03-23-2011
bars, fyi that last post was almost a year ago
#12 Old 03-24-2011
Vehicle: 98 SLK230 Black
I took a peice of copper wire and stuck it between the contact and the bulb and bent it over the contact, worked like a champ, and held me over till i could get new bulb holders. Thats all it was.
Wholesaleneon is offline
#13 Old 03-24-2011
wholesaleneon,
Please update your location/vehicle (model and year) in your profile as it helps the members answer any questions you might have based on your location and model and year.
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’ and ‘location’.
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘new members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
#14 Old 03-26-2011
you ever get it worked out
#15 Old 03-26-2011
johne likes this.
#16 Old 03-09-2015
johne's Avatar
Vehicle: 2000 SLK230 (facelift)
Other Toys: Subaru Outback wagon 4wd
Quoted: 18 Post(s)
Tried brightening contact and spray with electrical cleaner but still no joy. Odd failure of left light.
johne is offline
#17 Old 03-09-2015
TheBoss's Avatar
Vehicle: 1998 SLK230 Auto
Other Toys: Cummins, Raptor 700r
Since it's a known problem I suggest pulling both taillights and cleaning the contacts real well and put dielectric grease in the connector.
johne likes this.
TheBoss is offline
#18 Old 03-09-2015
Vehicle: 2003 SLK32 AMG
Other Toys: 73 Mustang convertible
Quoted: 15 Post(s)
Send a message via MSN to adrose Send a message via Skype™ to adrose
still using a piece of aluminum foil ,over a year,now.I think a new holder is around $20,but I am mean.....
adrose is offline
#19 Old 03-10-2015
johne's Avatar
Quoted: 18 Post(s)
Thanks for that great suggestion, I was just down at Supercheap and saw a wee sachet of what looks like just the stuff you are mentioning, will apply some and hope it helps.
I got the light working by wiggling the socket with the brakes and ignition on. Used a board jammed between the pedal and seat, as no assistance was around. It seems moving the bulb then powering the circuit doesn't work every time.
johne is offline
#20 Old 03-10-2015
johne's Avatar
Quoted: 18 Post(s)
Aaaah used to do that with Christmas tree lights when run out of spare bulbs.
Will try that next, meantime wiggling the bulb with power to the circuit did the rick, for now.
I'm with you on saving money, enough spent on this little car already but I still love it,
johne is offline
NoRegret4Life's KLEYMAN Flashing 3rd Brake Light Module SLKman SLK R170 General Discussion 54 11-13-2016 06:58 PM
Brake Light Flasher noregret4life General Modifications R171 221 02-10-2009 07:38 AM
Rear Brake Light Keeps "not working" SLKman SLK R170 General Discussion 8 09-07-2006 02:10 PM
